Assuming AC we know that all $\beth_\alpha$'s will be $\aleph_\beta$ for some $\beta$ since they can be well ordered.
Can anything interesting be said about their relationship without AC? Is it possibly consistent that with the exception of $\beth_0$ none of the $\beth$'s can be well-ordered?
Asaf Karagila
  • 393,674
DRF
  • 5,167
In $\sf ZF$ the two are equivalent:
  1. The axiom of choice.
  2. Every $\beth$ number is an $\aleph$ number.
You can prove this by going through the following equivalent statement,
  1. The power set of an ordinal can be well-ordered.
So if the axiom of choice fails, we know that there is some $\alpha$ such that $\beth_\alpha$ cannot be well-ordered. Interestingly, the least such $\alpha$ can be a limit cardinal, and in fact it can be $\omega$.
Other than that we cannot say much. We know it is consistent that $\aleph_1$ is incomparable with $\beth_1$, for example, in which case there is no $\beth$ number (other than $\beth_0$, that is) which can be well-ordered.
Asaf Karagila
  • 393,674
    For the OP: note that if $\beth_\alpha$ is not well-orderable, then $\beth_\beta$ is not well-orderable for any $\beta>\alpha$. So in fact $\neg AC$ is equivalent to "'most' $\beth$-numbers aren't well-orderable." – Noah Schweber Jul 22 '16 at 13:39
  • @NoahSchweber Ahh thank you that is a very good point. I must say I didn't realize that though it's actually fairly obvious thanks to canonical inclusions and sub orders of well orders being well orders. – DRF Jul 22 '16 at 14:03
    @JacobWakem That's not true. Every aleph number is a generalized beth number, via $\beth_0(\kappa)=\kappa$, but "beth number" usually refers to numbers of the form $\beth_\alpha=\beth_\alpha(\omega)$. See https://en.wikipedia.org/wiki/Beth_number. – Noah Schweber Jul 22 '16 at 14:32
  • @JacobWakem It is not true that every beth is an aleph in the context of ZF (= set theory without choice), which is the context of this question. For example, if $\mathbb{R}$ is not well-orderable, then $\beth_1$ is not an aleph. Asaf's answer is right, and does not need correction. – Noah Schweber Jul 22 '16 at 14:39
    @JacobWakem That is not true - in the absence of the axiom of choice, you need to make a distinction between cardinalities, or general cardinals, and cardinals in the sense of aleph numbers, or well-orderable cardinals. The "cardinality" of a non-well-orderable set will never be an aleph-number, and in the absence of the axiom of choice such sets may exist. Indeed the point of Asaf's answer is that every beth is an aleph IFF choice holds. I suggest you do some reading into set theory without the axiom of choice. – Noah Schweber Jul 22 '16 at 14:45
    You might start by looking at https://en.wikipedia.org/wiki/Aleph_number#Role_of_axiom_of_choice or http://math.stackexchange.com/questions/258510/defining-cardinals-without-choice. – Noah Schweber Jul 22 '16 at 14:46
  • @NoahSchweber Oh yes I see that you are right. I thought the alephs were all of the cardinals and that well ordering was only pertinent at the class level (well ordering the class of cardinalities). I never said I was a good person... – Jacob Wakem Jul 22 '16 at 14:53
