A positive integer $n$ is called a balancing number if
$$1 + 2 + \cdots + (n − 1) = (n + 1) + (n + 2) + \cdots + (n + r) \tag{1}$$
for some positive integer $r$.
Problem: Find the general solution (closed-form expression) of equation $(1)$, in other words, find $f_1(m)=n, f_2(m)=r$ where $f_1, f_2$ are solution of $(1)$ for any integer $m \in \mathbb Z$.
I have asked a similar question with a constrain involving Pell's equation.
Michael
  • 489
this question has been repeated quite a bit lately. Here is where these numbers were introduced, in 1999, in The Fibonacci Quarterly. Notice how they say $n$ is such a number if and only if $\sqrt {8n^2 +1}$ is a square. It is not on this page, but the simplest description for isolating $n$ is the degree two linear recurrence, $$ n_{j+2} = 6 n_{j+1} - n_j, $$ which means you can write $n_j$ as $A \lambda_1^j + B \lambda_2^j,$ with real constants $A,B$ and the lambdas are the two roots of $$ \lambda^2 - 6 \lambda + 1 = 0. $$ Alright, $$ n_j = A \left( 3 + \sqrt 8 \right)^j + B \left( 3 - \sqrt 8 \right)^j$$ with $n_0 = 1, n_1 = 6, n_2 = 35,$ and so on.
Alright, calculated, more convenient to absorb numbers into changing the exponent to $j+1,$ so I get
$$ \color{blue}{ n_j = \frac{1}{2 \sqrt 8} \left( \left( 3 + \sqrt 8 \right)^{j+1} - \left( 3 - \sqrt 8 \right)^{j+1} \right)}$$ Yep, works for $j = 0$ and $j = 1.$
Let us name $w_j = \sqrt{ 8 n_j^2 + 1},$ $$ \color{blue}{ w_j = \sqrt{ 8 n_j^2 + 1} = \frac{1}{2 } \left( \left( 3 + \sqrt 8 \right)^{j+1} + \left( 3 - \sqrt 8 \right)^{j+1} \right)}$$
We also get $$ w_{j+2} = 6 w_{j+1} - w_j. $$
My memory was not completely wrong, I solved this exact problem last Wednesday, posted it somewhere on MSE. Meanwhile, here is enough information to reconstruct everything. The linear recurrence comes from applying Cayley-Hamilton to the "automorphism matrix" below
 jagy@phobeusjunior:~$ ./Pell_Target_Fundamental
  Automorphism matrix:
    3   8
    1   3
  Automorphism backwards:
    3   -8
    -1   3
  3^2 - 8 1^2 = 1
 w_j^2 - 8 n_j^2 = 1
Tue Jul 19 12:21:37 PDT 2016
w_j:  3  n_j:  1 ratio: 3  SEED   BACK ONE STEP  1 ,  0
w_j:  17  n_j:  6 ratio: 2.83333
w_j:  99  n_j:  35 ratio: 2.82857
w_j:  577  n_j:  204 ratio: 2.82843
w_j:  3363  n_j:  1189 ratio: 2.82843
w_j:  19601  n_j:  6930 ratio: 2.82843
w_j:  114243  n_j:  40391 ratio: 2.82843
w_j:  665857  n_j:  235416 ratio: 2.82843
w_j:  3880899  n_j:  1372105 ratio: 2.82843
w_j:  22619537  n_j:  7997214 ratio: 2.82843
Tue Jul 19 12:22:17 PDT 2016
 w_j^2 - 8 n_j^2 = 1
Will Jagy
  • 139,541
$$S=\sum_{k=1}^{n-1}k$$ $$S_1=\sum_{k=1}^r(n+k)$$ the solution of the problem is given by: $S-S_1=0$ anfd you get: $$n=r+\dfrac{1}{2}+\dfrac{1}{2}\sqrt{(8r^2+8r+1)}$$ or: $$n=r+\dfrac{1}{2}-\dfrac{1}{2}\sqrt{(8r^2+8r+1)}$$
As in the other answer, $n = r + 1/2 + 1/2 \cdot \sqrt{2(2r+1)^2-1}$. For $n$ to be an integer we need $t^2 = 2(2r+1)^2-1$ for some odd $t$. The solutions of $t^2-2u^2=-1$ are parameterized by $t+u\sqrt{2} = (1+\sqrt{2})^n$ for odd integers $n$ and will necessarily have $t,u$ odd (examine it mod 8). So for any such $t+u\sqrt{2}$, set $r = (u-1)/2$ and $n = (u-1)/2 + (t+1)/2$
