I need to resolve the following system of linear congruences:
$9 = 3a+c \pmod m$
$11 = 9a+c \pmod m$
$1 = 11a+c \pmod m$
How can I proceed?
Is there anyway to input these equations in Wolfram alpha (or another tool)?
$9 = 3a+c \pmod m$
$11 = 9a+c \pmod m$
$1 = 11a+c \pmod m$
How can I proceed?
We note that (for a fixed $m$) we have three linear congruences in two variables, so there is no particular reason to suppose that a solution exists. Indeed, for most $m$, no solution exists...as what follows will show.
Subtracting the first from the second we get $$6a\equiv 2 \pmod m$$
Subtracting the second from the third gives $$2a\equiv -10 \pmod m$$
Combining these give $$6a\equiv 3\times 2a\equiv 3\times (-10)\equiv -30\equiv 2\pmod m$$
Thus, $m$ divides $32$, so $m=2^n$ for $n≤5$
We will consider the case $m=32$.
The congruence $6a\equiv 2 \pmod {32}$ has solutions $a=11,27$. These give rise to the solutions $$(a,c)\equiv (11,8)\;or\;(27,24)\pmod {32}$$
The other cases for $m$ are similar.
Given the solutions mod $2^5$ in lulu's answer, I explain how to very simply generate the solutions mod $\,2^i\,$ for all $\,i\le 4.\,$ Doing the same elimination lulu did for the homogeneous system with $9,11,1$ replaced by $\,0,0,0$ we get $\,0 \equiv 2a\equiv 6a \equiv 8a \!\iff\! 2a \equiv 0.\,$ So $\,a \equiv 0\pmod {\!m/2}$ and this implies $\,c\equiv 0\pmod{\!m/2}.\,$ Hence two solutions differ by multiple of $\,(m/2,m/2).\,$ So given any particular solution $\,(a,c),\,$ there will be one other solution $(a,c)+(m/2,m/2).\,$ But we already know a particular solution: $ $ reduce mod $\,m = 2^i$ the solution mod $\, 2^{i+1}.$
For example, the solutions $\,(a,c)\equiv (11,8),(27,24)\pmod{\!2^5}\,$ reduce to the solution $\,(11,8)\pmod{\!2^4}.$ The other solution(s) arise by adding multiples of $\,(m/2,m/2)=(8,8),\,$ hence there is one other solution $\,(11,8)+(8,8)\equiv (3,0)$.
These map to $\,(3,0)\pmod{\!2^3}\,$ with one other solution $\,(3,0)+(4,4)\equiv (7,4),\,$
These map to $\ \ \: \ldots\pmod{\!2^2}\, $ with $\ \ldots$
