53
What is the difference between max, min and sup, inf?
piotrek
  • 673
The main difference is that the infimum and supremum always exists (if you allow the values $\pm \infty$) but the minimum and maximum doesn't.
If the set is finite then it is trivial, as a finite set always has a maximal and minimal element, but if you look at something like:
$A = \{x \in \mathbb{Q}: x > 0\}$.
Then you cannot find a smallest element in the set as when you find some candidate for the smallest element, the half of it is still smaller. And $0 \notin A$, therefore the Minimum doesn't exist. In contrast to this the Infimum is just the biggest lower bound and doesn't have to be in $A$ itself, (not even in $\mathbb{Q}$). You can easily see that $\text{inf}(A)=0$.
Another example is $B = \{x \in \mathbb{Q}: x>0,x^2 > 2\}$.
Certainly $\sqrt{2} \notin \mathbb{Q}$ therefore the minimum doesn't exist as for every candidate for your minimum you can go closer to $\sqrt{2}$ and find a smaller one ($\mathbb{Q}$ is dense in $\mathbb{R}$), but the infimum is $\text{inf}(B)=\sqrt{2}$.
Otherwise if the minimum or maximum does exist, it is surely equal to the infimum/supremum as it is the biggest lower / least upper bound in this case.
Listing
  • 13,937
  • @Listing, a bit late to the party, but I guess on the second-to-last paragraph everytime you said minimum you meant maximum or supremum. And smaller actually meant larger. Right?? – ivbc Feb 17 '18 at 23:48
If we have a set $A$ and some partial ordering on $A$, for $B$ a subset of $A$ then we define the $\sup$ of $B$ (denoted $\sup B$) as the least element $a$ such that:
  1. $\forall b\in B\colon b<a$ or $b=a$ ($a$ is an upper bound of $B$)
  2. If $c$ is such that the above condition holds for $c$ (that is $c$ is an upper bound of $B$) then $a<c$ or $a=c$ (namely, every upper bound of $B$ is at least $a$).
In the case that $a=\sup B$ and $a\in B$ we say that $a$ is the maximum of $B$ and denote it by $\max B$. Note that this is not always the case, as presented in other answers $1=\sup \{x\in\mathbb{Q} : x<1\}$ but it is not a maximal element of the set.
The definitions for $\inf$ and $\min$ are symmetric when replacing upper bound by lower bound, etc.
Note, however, that not every order relation has this property of having upper bounds, not even for bounded subsets. It is easy to construct an order in which there is a bounded set which has neither $\sup$ nor $\inf$ (and thus no $\max$ and $\min$ as well).
For example, consider $\{a,b,c\}$ and define $a<b$ and $a<c$ however $b$ and $c$ are incomparable, that is both $b<c$ and $c<b$ are false.
The subset $\{a\}$ is bounded, as $b$ and $c$ are both upper bounds, but neither of those is a least upper bound. In this case $a$ is a minimum element of $\{a\}$, but you can add a few more elements in a similar fashion to have that a subset of two incomparable elements has no $\sup$ nor $\inf$.
When discussing real numbers then we always have a supremum, this is a result of the Dedekind cuts construction of the real numbers, which guarantee that every bounded subset has a supremum and infimum.
Asaf Karagila
  • 393,674
For a bounded set $A \subset \mathbb{R}$ we have the following:
  • $\max A \ \text{exists and equals} \ \sup A \Longleftrightarrow \sup A \in A$
  • $\min A \ \text{exists and equals} \ \inf A \Longleftrightarrow \inf A \in A$
    @PEV: Maximum and minimum do apply to infinite sets. For instance, $\min [0,1) = 0 = \inf [0,1)$, and $\sup [0,1) = 1$, but $[0,1)$ has no maximum. – lhf Jan 23 '11 at 10:30
    @PEV: The right sides of your equivalences don't make sense if $\mathrm{max}(A)$ resp. $\mathrm{min}(A)$ does not exist. Therefore, these equivalences are incorrect. – Rasmus Jan 23 '11 at 10:42
  • @PEV: What is the supremum of an arbitrary set? – Rasmus Jan 23 '11 at 10:46
  • @Rasmus: What is resp? – NebulousReveal Jan 23 '11 at 10:55
  • I used resp. as an abbreviation for respectively. – Rasmus Jan 23 '11 at 10:58
  • So what are you saying? If max A respectively min(A) does not exist? What does that mean? – NebulousReveal Jan 23 '11 at 10:59
  • I would write "$\max A$ exists and equals $\sup A \iff \sup A \in A$ (or '$A$ contains/attains its supremum')" instead – kahen Jan 23 '11 at 11:04
  • @PEV: If max does not exist than the statement max=sup does not make sense. Similarly for min and inf. – Rasmus Jan 23 '11 at 11:09
  • @kahen: I agree. – Rasmus Jan 23 '11 at 11:10
  • @Rasmus: But thats the whole point. IF max A exists then max A = sup A. Similarly, IF min A exists then min A = inf A. – NebulousReveal Jan 23 '11 at 11:14
  • @PEV: That's not what you express with your formulas above. – Rasmus Jan 23 '11 at 11:44
  • @Rasmus: This is what the above formulas express: (i) if max A exists then max A = sup A and (ii) if max A = sup A then max A exists. – NebulousReveal Jan 23 '11 at 11:50
    Okay, so this is my last try: "(ii) if max A = sup A then max A exists." is a meaningless statement because saying max A = sup A only makes sense given that max A exists. – Rasmus Jan 23 '11 at 11:56
  • Your statement $\text{max} A$ exists and equals $\text{sup} A$ suggests that there is a case where $\text{max} A$ exists and doesn't equal $\text{sup} A$, which is false. – Listing Jan 23 '11 at 19:06
Every bounded subset $S$ of the reals has a supremum and an infimum. The supremum, for instance, is just the smallest number which is greater or equal to every element in $S$. This number, however, may not belong to $S$ -- this happens for example for $S=(0,1)$, as lhf noted. In this case, you would say that $S$ does not have a maximum/maximal element. The reason is that a maximum of $S$ is an element of $S$ which is greater or equal to every element in $S$. Such an element may or may not exist, but if it exists it is unique, which justifies the use of the definite article.
Rasmus
  • 18,404
