It is well known that for two numbers $a $ and $b$, $$\text {lcm} (a,b)\times \text {hcf} (a,b)=ab$$ Does there exist a similar equality/ inequality between HCF, LCM and product of multiple numbers? (i.e. some relation between $\text {hcf} (a_1,a_2,...,a_n)$, $\text{lcm} (a_1,a_2,...,a_n)$ and $a_1\times a_2 \times ...\times a_n$)
- 330,363
- 3,363
- 2
- 26
- 47
The product of the lcm and hcf of $(2,2,2)$ is $4$. For $(1,1,8)$ it is $8$. Same product. – André Nicolas Jul 15 '16 at 05:32
I asked for a similar equality/ inequality, not an exact one. – Apurv Jul 15 '16 at 05:34
In general there will be an inclusion-exclusion equality relating $lcm(a_1,\ldots,a_n)$ to the $gcd$ of each subset of ${a_1,\ldots,a_n}$. See https://en.wikipedia.org/wiki/Inclusion%E2%80%93exclusion_principle – stewbasic Jul 15 '16 at 05:36
@Apury: The fact that in the example the products $a\times b\times c$ are different shows that the product of lcm and hcf is not a function of the product of the three numbers. – André Nicolas Jul 15 '16 at 05:37
I know an inequalitu that relates the first n natural numbers. So i was thinkingthat could probably be done for any n numbers. Any suggestions? – Apurv Jul 15 '16 at 05:40
@Apurv: Eric Wofsey has given an inequality, which can also be proved by induction. – André Nicolas Jul 15 '16 at 05:49
You cannot express $a_1a_2\dots a_n$ in terms of $\gcd(a_1,a_2,\dots,a_n)$ and $\operatorname{lcm}(a_1,a_2,\dots,a_n)$ in any way if $n>2$. For instance, if $n=3$, note that $\{2,4,16\}$ and $\{2,8,16\}$ have the same GCD and LCM, but they have different products. You can find similar examples for any $n>2$.
For an inequality, I don't know what sort of thing you're looking for. But it is straightforward to see that $$\gcd(a_1,a_2,\dots,a_n)\operatorname{lcm}(a_1,a_2,\dots,a_n)\leq a_1a_2\dots a_n$$ whenever $n\geq 2$ (just compare the $p$-adic valuations of both sides for each prime $p$--the left-hand side is the sum of the valuations of two of the $a_i$, while the right-hand side is the sum of the valuations of all of them).
- 330,363
Any inequality you are aware of? I know one that relates the first n natural numbers. – Apurv Jul 15 '16 at 05:38
Not with just product.
The product of the lcm and hcf of $(2,2,2)$ is $4$. For $(1,1,8)$ it is $8$. But $2\times 2\times 2=1\times 1\times 8$.
Thus the product of lcm and hcf is not a function of the product of the three numbers.
Similarly, note that $(2,2,4)$ and $(2,4,4)$ have the same lcm and hcf. But their products are different, so the product of three numbers is not a function of their lcm and hcf.
- 507,029
