I have a sphere and 2 points on it. I know everything about these points to be able to define them in 3 dimensional space with both cartesian coordinate system and polar coordinate system (x, y and z position of the points; angles and radius).
I need to find the shortest distance between this point on the sphere's surface.
Bálint
  • 299
    It is the great circle distance. In order to find this, use the formula $s=r\theta$ where $s$ is what you are required to compute, $r$ is the radius of the sphere, and $\theta$ is the angle subtended by the arc connecting the two points at the center of the sphere. – P. N. Karthik Jul 12 '16 at 13:38
  • @Karthik Figuratively, you are asking to walk from Point A to B along the surface of the sphere? What if we connect A and B through the sphere, won't that be shortest? – MonK Jul 12 '16 at 13:43
  • Sorry my mistake, I did not read the last part of the question! :) – MonK Jul 12 '16 at 13:46
Hint:
If $\mathbf {p_1}$ and $\mathbf {p_2}$ are the two points, note that $|\mathbf {p_1}|=|\mathbf {p_2}|=r$ ( the radius of the sphere).
Now find the angle $\alpha$ betveen the two points using the dot product: $$ \alpha=\arccos (\frac{\mathbf {p_1}\cdot \mathbf {p_2}}{r^2}) $$
and the distance between them is $ d=r\alpha$.
Emilio Novati
  • 62,675
