If you know matrices, this will do it: Regard $P$, $v$, and $w$ are column vectors. Let $M$ be the matrix whose two columns are $v$ and $w$. It's an $n\times2$ matrix. (By the way, you shouldn't use capital $N$ and lower-case $n$ as if they were synonymous. Mathematical notation is case-sensitive.) Then $M^TM$ is a $2\times 2$ matrix, which is invertible if the vectors $v$, $w$ are linearly independent. The matrix $M(M^TM)^{-1}M^T$ is and $n\times n$ matrix of rank $2$. The vector $M(M^TM)^{-1}M^T P$ is the projection that you seek.
"Usage note": Once upon a time a highly respected and moderately famous mathematician told me that $M(M^TM)^{-1}M^T$ is the identity matrix. Apparently he was assuming $M$ was a square matrix. I have a bold hypothesis, which I haven't checked empirically: "Pure" mathematicians tacitly assume matrices are square; "applied" mathematicians don't.
