I am a 10th grade student and there is a statement in my math book
If $a$ is a root of the polynomial $f(x)$ then $(x-a)$ is a divisor of $f(x)$
Why is $(x-a)$ a divisor of $f(x)$? Can you please tell me?
It's a great thing that you feel curiosity for the reasons of the statements that are taught to you!
For this, you have to know a little bit about long division of polynomials. Just like integers, we can divide polynomials, obtaining a quotient and a remainder. More precisely:
Given any polynomials $f$ and $g$, there exist polynomials $q$ (the quotient) and $r$ (remainder) such that $$f = q\cdot g + r$$ and the degree of $r$ is strictly smaller than the degree of $g$.
Now, try to prove your theorem. At first, assume that $a$ is a root of $f(x)$, set $g(x) = x-a$ and apply long division (I'm sure you can do it). The procedure is below, but try to do it by yourself at first.
If we apply long division, you get $q$ and $r$ such that $f = q\cdot (x-a) + r$ and $r$ has degree $0$ (why?), so $r$ is a constant. Since $f(a)=0$, we got $0=f(a)=q(a)\cdot (a-a) + r = 0 + r = r$, so $r=0$ and therefore $f = q\cdot (x-a)$.
The other direction is even easier: if $f(x) = q(x)\cdot(x-a)$, can you see why $f(a)=0$?
Let $$ f (x)=a_n x^n+... +a_1 x+a_0 $$ Suppose $ f (r)=0$. Hence $$ a_n r^n +... + a_1 r +a_0 =0$$
Then $$ f (x)=a_n x^n + ... + a_1 x + a_0 - ( a_n r^n +... + a_1 r +a_0) $$
since the expression between parentheses is zero.
After reordering,
$$ f (x) = a_n (x^n - r^n) + ... + a_1 ( x-r) $$ Note that $$ b^n - t^n= (b-t)(b^{n-1} + b^{n-2} t+... + b t^{n-2}+ t^{n-1})$$ (you can check it?) Hence $$\begin{align} f (x)&= a_n (x-r)(x^{n-1}+...+r^{n-1})+...+a_1 (x-r)\\&= (x-r)(a_n (x^{n-1}+...+r^{n-1})+...+a_1) \end{align}$$ For example, suppose $$ f (x)= a_2 x^2+a_1 x + a_0 $$ and $ f (r)=0$. Hence $$\begin{align} f (x) &= a_2 x^2 + a_1 x + a_0 - ( a_2 r^2 + a_1 r + a_0)\\&= a_2 (x-r)(x+r)+ a_1 (x-r)\\&= (x-r)(a_2 (x+r)+ a_1) \end{align}$$
This is essentially Factor Theorem, which is a consequence of Remainder Theorem
If you let the polynomial $f(x)$ be represented as $f(x) = (x-a)Q(x) + R$, then you will note that the remainder $R = 0$ if and only if $f(a) = 0$ (i.e. $a$ is a root of $f(x)$). In this circumstance, the polynomial may be represented by $f(x) = (x-a)Q(x)$ and therefore $f(x)$ is divisible by $(x-a)$.
Recall the factor theorem for polynomials. $$f(x) = (x-a) q(x) + r$$ where $r = f(a)$.
Lemma $:$ For a field $F, \alpha \in F$ is a root of $a(x)$ if and only if $x-\alpha$ divides $a(x)$
Proof. $(\Longrightarrow)$ Assume that $\alpha$ is a root, i.e., $a(\alpha)=0 .$ Then we can write $a(x)$ as $$ a(x)=(x-\alpha) q(x)+r(x) $$ where $\operatorname{deg}(r(x))<\operatorname{deg}(x-\alpha)=1,$ i.e., $r(x)$ is a constant $r,$ where $$ r=a(x)-(x-\alpha) q(x) $$ Setting $x=\alpha$ in the above equation gives $$ r=a(\alpha)-(\alpha-\alpha) q(\alpha)=0-0 \cdot q(\alpha)=0 $$ Hence $x-\alpha$ divides $a(x)$
($\Longleftarrow$) To prove the other direction, assume that $x-\alpha$ divides $a(x),$ i.e., $a(x)=$ $(x-\alpha) q(x)$ for some $q(x) .$ Then $a(\alpha)=(\alpha-\alpha) q(\alpha)=0,$ i.e., $\alpha$ is a root of $a(x)$
