I was trying to find the value of x in the following equation.
$$x=\sum _{ i=0 }^{ \infty } \left( i+1 \right) \cdot \left( \frac { 5 }{ 6 } \right) ^{ i }$$
In a computer simulation, I found that $x=6^2$
I believe the following is also true, I just do not know how to prove it. $$p^2=\sum_{i=0}^{ \infty } (i+1)\dot\ (\frac{p-1}{p})^i$$
Could anyone tell me what theory I should look into to for this problem?
haqnatural
  • 21,578
Xin
  • 101
    The sum depends on $n$, so you will not get that. If you meant to sum to $\infty$, see http://math.stackexchange.com/q/30732/ – Jonas Meyer Jun 30 '16 at 06:34
The series
$$\sum_{n=1}^{\infty} nr^n$$
converges when $|r| < 1$ and is equal to $\dfrac{r}{(r-1)^2}$.
Here's a quick way to prove it:
$$\frac{1}{1-r} = \sum_{n=0}^{\infty} r^n$$
Ignoring questions about justification, differentiate both sides (the right term-by-term) to get
$$\frac{1}{(1-r)^2} = \sum_{n=1}^{\infty} nr^{n-1}$$
and multiply by $r$ to get the result.
MT_
  • 19,603
  • 40
  • 81
$$x=\sum _{ i=0 }^{ \infty } \left( i+1 \right) \cdot \left( \frac { 5 }{ 6 } \right) ^{ i }$$ $$\frac{5x}{6}=\sum _{ i=0 }^{ \infty } \left( i+1 \right) \cdot \left( \frac { 5 }{ 6 } \right) ^{ i+1 }$$ $$x-\frac{5x}{6}=1+\sum_{i=1}^{\infty}\left( \frac { 5 }{ 6 } \right) ^{ i }$$ after this is basic G.P formula
avz2611
  • 3,658
A slightly more general identity is given by stars and bars: $$\frac{1}{(1-z)^{k+1}}=\sum_{n\geq 0}\binom{n+k}{n}z^n\tag{1} $$ for any $z$ such that $\|z\|<1$. Just take $k=1$ and $z=\frac{5}{6}$.
Kamala
  • 170
