I need to prove the n-th Fibonacci number is less than $2^n$ for all $n \geq 0$ using strong induction.
I have been exposed to the idea that strong induction differs from weak induction in that the pattern upon which induction is based often does not repeat at every value of $n$. ( For example, the nth term in a sequence might be defined in terms of the $n - 4$th term, as opposed to the $n - 1$ term, "reaching back four terms" as it were. )
The Fibonacci sequence "reaches back" two terms. So, I show for two base cases that the predicate is true for $n = 0$ and $n = 1$:
$ \begin{align} F_0 &= 1 \leq 2^0 \\ F_1 &= 1 \leq 2^1 \\ \end{align} $
Then, I state the inductive hypothesis:
$ \left(\ \forall\ k \in \mathbb{N} \cup \left\{ 0 \right\} \ \right) \left(\ F_k = F_{k-1} + F_{k-2} \leq 2^k \ \right) $
From there, I step forward twice:
$ \left(\ \forall\ k \in \mathbb{N} \cup \left\{ 0 \right\} \ \right) \left(\ F_k = F_{k-1} + F_{k-2} \leq 2^k \ \right) \\ \left(\ \forall\ k \in \mathbb{N} \cup \left\{ 0 \right\} \ \right) \left(\ F_{k+1} = F_{k} + F_{k-1} \leq 2^{k+1}\ \right) \\ \left(\ \forall\ k \in \mathbb{N} \cup \left\{ 0 \right\} \ \right) \left(\ F_{k+2} = F_{k+1} + F_{k} \leq 2^{k+2}\ \right) \\ $
And from there--I think--I should be able to do some substitution or other simple arithmetic operation to show that the inductive step is true if any base case is true.
But, I'm just not seeing it.
Any help would be appreciated.
