While dealing with a question about a prime ideal $I\subset\mathbb{Z}[x]$ (with $0$ as the only constant polynomial in $I$) I was asked to show that there exists $f(x)\in\mathbb{Z}[x]$ such that $I=\left<f(x)\right>$ and got stuck.
How do I know that some ideal is generated by only one element?
What have i tried:
i) Looked at $I$ and tried to adapt the proof that integers is a principal ideal domain and and so as $I$ is an ideal of itself I'd be done, but no success.
ii) Ignored one operation and tried to see I as a subgroup, but that was a rather unsuccessful strategy.
I appreciate any hints and book references where i can find proper explanations.
user26857
  • 52,094
Alan246
  • 120
  • This is not really a duplicate! This is a special case, which can be treated with simpler methods. The OP might not know about integrally closed domains and therefore the techniques used for answering that question might not be helpful. – Hamed Jun 27 '16 at 09:16
  • @Hamed If you read carefully the answers in the original thread can notice that the proofs rely on Gauss' Lemma which is well known for polynomials over $\mathbb Z$, and less known for integrally closed domains. – user26857 Jun 27 '16 at 10:09
  • Old question, but for future reference : A simple proof(which does rely on gauss' lemma) can be given using the fact that if $f$ and $g$ are polynomials with no common factor in $\mathbb{Z}[x]$(hence in $\mathbb{Q}[x]$), there exists polynomials in $\mathbb{Z}[x]$ such that $uf+vg=c$ for a nonzero constant polynomial $c$. – Hyunbok Wi Apr 05 '21 at 22:27
This is a long and messy proof, and I don't think there is any easier way to deal with it unless some additional knowledge about commutative algebra is available. If I made a mistake somewhere please let me know... If you prefer to prove it yourself just read the claims and the lemma and try to prove them yourself without reading my proof (which is actually better...)
Definition: A polynomial $p(x)\in \mathbb{Z}[x]$, i.e. $p(x)=n_dx^d+\cdots+ n_0$ is called a primitive polynomial if $\mathrm{gcd}(n_0, \cdots, n_d)=1$.
Now suppose $I\subset \mathbb{Z}[x]$ is a prime ideal in which the only constant polynomial is zero. Take any polynomial $I\ni f(x)=a_\ell x^\ell+\cdots+ a_0$. Let $c=\mathrm{gcd}(a_0, \cdots, a_\ell)$. Then $a_i = c \tilde{a}_i$. Then the polynomial $\tilde{f}(x)=\tilde{a}_\ell x^\ell+\cdots+ \tilde{a}_0$ is primitive. Moreover $f(x)=c\tilde{f}(x)\in I$. Since $I$ is prime and $0\neq c\notin I$ we have $\tilde{f}(x)\in I$. Hence
Claim: If $f(x)\in I$ then the primitive polynomial $\tilde{f}(x)$ corresponding to it is also in $I$.
Now
Claim Let $p_1(x), p_2(x)\in I$ be two non-zero primitive polynomials in $I$ of minimal degree. Then $p_1(x)=p_2(x)$.
Proof: Suppose $\deg p_1=\deg p_2=D$.
  • Suppose $\deg (p_1(x)-p_2(x))=D$. If $p_i(x)= b_{iD}x^D+\cdots+b_{i0}$ for $i=1,2$. Let $m=\mathrm{lcm}(b_{1D}, b_{2D})$. Let $q_1, q_2\in \mathbb{Z}$ be such that $p_1q_1=m$ and $p_2q_2=m$. Then $$ mx^D+q_ib_{i,D-1}x^{D-1}+\cdots+q_ib_{i0}\in I, \quad $$ for $i=1,2$. As a result $(q_1b_{1,D-1}-q_2b_{2,D-1})x^{D-1}+\cdots+(q_1b_{10}-q_2b_{20})\in I$. Suppose this polynomial is non-zero. Let $Q(x)$ be the primitive polynomial corresponding to this polynomial. Then $Q(x)$ is a primitive polynomial of lower degree than $D$, contrary to assumption. So we must have $q_1p_1(x)=q_2p_2(x)$, but then since $p_1, p_2$ are primitive $q_1=q_2$.
  • Suppose $\deg (p_1-p_2)<D$. If $p_1(x)\neq p_2(x)$, denote by $0\neq P(x)$ the primitive polynomial corresponding to $p_1(x)-p_2(x)$, then $\deg P(x)<D$ contrary to $p_1, p_2$ being primitive of minimal degree, which again means $p_1(x)=p_2(x)$.
Claim Denote by $p(x)$ the unique primitive polynomial of least degree in $I$. Then $I=\langle p(x)\rangle$.
Proof: First of all note that if $x\in I$, then $I=\langle x\rangle$ since the only constant polynomial in $I$ zero and $I$ is prime. So suppose $x\notin I$. Given any $g(x)\in I$ now we can write $g(x)=x^r g'(x)$ for some $r\geq 0$ and $g'(x)\in \mathbb{Z}[x]$ such that $x$ does not divide $g'(x)$. But then since $I$ is prime and $x\notin I$ we have $g'(x)\in I$.
So without loss of generality consider only primitive polynomials of the form $I\ni g(x)=a_Nx^N+\cdots+a_0$ with $a_0\neq 0$. Also write $p(x)= b_Dx^D+\cdots+b_0$ with $b_0\neq 0$ too (this is because of minimality and $x\notin I$). We either have $g(x)=p(x)$ or $\deg g>\deg p$ by uniqueness. In the former case there is nothing to prove. So assume the latter. Let $m=\mathrm{lcm}(a_0, b_0)$ and $q_1, q_2$ such that $a_0q_1=m$ and $b_0q_2=m$. Then $q_1g(x)-q_2p(x)\in I$ and $x$ divides it, i.e. $$ q_1g(x)-q_2p(x) = x^r g_1(x) $$ with $r>0$ some power. But then $g_1(r)\in I$ too, which means the primitive polynomial corresponding to it $\tilde{g}_1$ is also in $I$. Now $\deg \tilde{g}_1(x)=\deg g_1(x)<\deg g(x)$. Due to this relation of between degrees one possibility is $\tilde{g}_1(x)=p(x)$. In which case $g_1(x)=c\tilde{g}_1(x)$ for some $c\in \mathbb{Z}$ and $$ q_1g(x)=[q_2+cx^r]p(x) $$ Now by the lemma I prove at the end $g(x)\in \langle p(x)\rangle$. So consider the case where $\tilde{g}_1(x)\neq p(x)$. Then by repeating the process for the pair $\tilde{g}_1, p(x)$ we another primitive polynomial $\tilde{g}_2(x)$ such that $\deg \tilde{g}_2< \deg \tilde{g}_1$. Then either $\tilde{g}_2=p(x)$ or $\tilde{g}_2\neq p(x)$. The fomer case gives us the assertion again. Assuming the latter case we get (inductively) a chain of primitive polynomials $g(x), \tilde{g}_1(x), \tilde{g}_2(x), \cdots$ all in $I$ such that the degree is strictly decreasing. So eventually you will have a case $\tilde{g}_n(x)=p(x)$. And the is finishes the job.
Lemma Let $f(x), g(x), h(x)$ be polynomials in $\mathbb{Z}[x]$ such that $f(x)=g(x)h(x)$. Then if $\tilde{f}(x), \tilde{g}(x), \tilde{h}(x)$ are the primitive polynomials corresponding to them, we have $\tilde{f}(x)=\tilde{g}(x)\tilde{h}(x)$.
Proof: This basically boils down to the fact that the product of two primitive polynomials is primitive. For a simple proof see here.
Hamed
  • 6,793
  • My answer contradicts somehow your opinion about the non-existence of a short proof using only elementary facts. – user26857 Jun 27 '16 at 05:38
  • You use things like euclidean division on polynomials. I actually tried deliberately to bypass that. But you're right once one knows this ring is a gcd domain the proof gets significantly shorter. – Hamed Jun 27 '16 at 05:46
  • User26857: I just look at your answer to the question, I think there is a difference this issue and the issue is treated here, in fact the question to which you answered suppose that the prime ideal $ P$ contains a unitary polynomial, unlike here the ideal $I$ can not contain any unitary polynomial. Thanks – m.idaya Jun 27 '16 at 11:56
  • @m.idaya You certainly didn't look well: if $R$ is a UFD (in particular, $R=\mathbb Z$) then $S^{-1}P=pK[X]$ for some $p\in P$, $p$ primitive. Now let $f\in P$. Write $f=pg$ for some $g\in K[X]$. Moreover, $g=\frac abg_1$ with $g_1\in R[X]$, $g_1$ primitive, and $a,b\in R$. Since $pg_1$ is primitive we get $f\in (p)$. (Can you see the Gauss' Lemma at work?) – user26857 Jun 27 '16 at 21:08
let $P$ and $Q$ are in $I$ of minimum degree so $degP=degQ$. in the case one is unitary for example $P$, then $I=(P)$ this by Euclidean division and end. so we suppose that all $P$,for which degree are the minimum degree of element in $I$, are not unitary.
so we suppose $P$ and $Q$ are not unitary but primitive because we can always write $P=gcd(a_i,i=0,...n)P_1$ with $P_1$ primitive (hypothesis that $I$ prime and no constant polynomial other zero in $I$).
so we prove that $P=Q$ and $I=(P)$ .
the polynomial $b_nP-a_nQ$ is in $I$ where $a_i$ and $b_i$ are the coefficient of $P$ and $Q$ respectively. so this polynomial must be zero (by minimal degree of element of $I$) and so $ P=Q$ this prove that each element $Q$ in $I$ s.t $degre Q= deg P$ that $ Q=cP$ for some constant c.
Now we prove by recurrence on degree of $Q$ that $Q= C(X)P(X)$.
so suppose $degQ=(degP)+1=n+1$.
$Q=b_{n+1}X^{n+1}+...+b_0\in I$ so $a_nQ-b_{n+1}XP\in I $ of degre n (note: if equal to zero then $a_nb_0=0$ and $Q=XL$ with $degrL=n$ so $L=cP$, because $X$ unitary so $X$ is not in $I$ ) so is of form $cP$, by substitution $X=0$, we conclude that $a_nb_0=ca_0$ and this applique $b_0=a_0b'_0$ ($a_0, a_n$ are coprime numbers ). so $Q-b'_0P=c'XP$ and this applique $Q=AP$.
suppose that each $R\in I$ of degree $i$, $n< i< m$ is in the forme $AP$. (also we use the same technique as in the case $i=n+1$ we obtain the result).
let $Q\in I$ s.t $degrQ=m$, then $a_nQ-b_mXP\in I $ of degree $m-1$ (suppose not zero as in the above case) and so is of the forme $C(X)P(X)$; by tacking $X=0$, we have $a_nb_0=c_0a_0$ so $b_0=a_0b'_0$ and $Q(X)-b_0P(X)=XL(X)\in I$, so $L=bP$ and $Q=AP$.
m.idaya
  • 1,558
