Possible Duplicate:
How come the number $N!$ can terminate in exactly $1,2,3,4,$ or $6$ zeroes but never $5$ zeroes?
The number of zeros which are not possible at the end of the $n!$ is:
$a) 82 \quad\quad\quad b) 73 \quad\quad\quad c) 156 \quad\quad\quad d) \text{ none of these }$
I was trying to solve this problem. I know how to calculate the no of zeros in factorial but have no idea how to work out this problem quickly.
user5918
  • 141
  • Is there something that precludes you from simply computing the first few hundred factorials on a computer, then inspecting their digits? – Douglas S. Stones Jan 20 '11 at 08:13
  • Yes. This question belongs to a quantitative aptitude section of CAT(Common aptitude test) which must be answered in least possible time(varying from 1 to 3 mins) – user5918 Jan 20 '11 at 08:17
  • This recent question is related: http://math.stackexchange.com/q/17916/1242. – Hans Lundmark Jan 20 '11 at 09:16
    So this is not really homework... btw, @user5918, you seem to posting a lot of questions without actually showing any of your working. It is considered to be in bad form to do that. Please put some thought/effort into your questions before asking them here. – Aryabhata Jan 20 '11 at 09:29
Assuming there is a single answer, the answer is $73$.
Consider $300!$, it has $300/5 + 60/5 + 10/5 = 74$ zeroes. $299!$ has $59 + 11 + 2 = 72$ zeroes.
Got this by trial and error and luck.
Note this is an application of Legendre's formula of the highest power of a prime $p$ dividing $n!$ being $$\displaystyle \sum_{k=1}^{\infty} \left \lfloor \frac{n}{p^k} \right \rfloor$$.
We only need to consider power of $5$ to get the number of zeroes.
Since you asked for a method:
For smallish numbers, you could try getting a multiple of $6 = 1+5$ close to your number, find the number of zeroes for $25/6$ times that and try to revise your estimate.
For example for $156 = 6*26$.
So try $26*5*5 = 650$. $650!$ has $26*5 + 26 + 5 + 1 = 162$ zeroes.
Since you overshot by $6$, try a smaller multiple of $6$.
So try $25*5*5$, which gives $25*5 + 25 + 5 + 1 = 156$. Bingo!
For $82$, try $78 = 13*6$.
So try $13*25$. Which gives $65 + 13 + 2 = 80$ zeroes.
So try increasing the estimate, say by adding 10 (since we were short by 2).
$13*25 + 10$ gives us $67 + 13 + 2 = 82$ zeroes.
For $187$ Try $186 = 6*31$.
So try $31*5*5$ this gives us $31*5 + 31 + 6 + 1 = 193$ zeroes.
since we overshot by $7$, try reducing it, say
$30*5*5$ gives us $30*5 + 30 + 6 + 1 = 187$
For larger numbers instead of multiple of 6, consider multiple of $1+5+25$, $1+5+25+125$ etc.
I am pretty sure there must be a better method, but I don't expect the CAT folks to expect candidates to know that!
Hope that helps.
Quixotic
  • 22,431
Aryabhata
  • 82,206
    if the option changes to some other prime number greater than say 103 or 187 than this is sure that it will not work in time limit varying (1-5)min could you provide me the general solution to this problem so that the wrong answer could be straight away discarded – user5918 Jan 20 '11 at 08:37
If you know how to calculate the number of zeros at the end of $n!$, then you know that there are some values of $n$ for which the number of zeros has just increased by 2 (or more), skipping over number(s). What numbers are skipped?
Further hint (hidden):
Find the number of zeros are at the end of (a) $24!$; (b) $25!$
edit more explicitly:
the factorials of 5-9 end in 1 zero, 10-14 end in 2 zeros, 15-19 end in 3 zeros, 20-24 end in 4 zeros, 25-29 end in 6 zeros, so 5 is the first number skipped. For what $n$ will the number of zeros at the end of $n!$ next skip over an integer and what is that number of zeros?
Isaac
  • 36,557
  • no clue what so ever – user5918 Jan 20 '11 at 08:45
    Not sure if I would recommend this method for an exam which has 2-3 minutes allotted to each question. – Aryabhata Jan 20 '11 at 09:34
  • @Moron: I strongly suspect that in 2-3 minutes, I could generate a list of the skipped numbers up to around 300 or so, but I haven't actually tried it yet. – Isaac Jan 20 '11 at 10:16
  • I certainly could generate such a list up to 156 by hand in 3 minutes and find time to double check it. Now if it took 3 minutes to decide that I wanted to generate such a list, that's a different issue... – Barry Smith Jan 20 '11 at 12:31
  • i have tried to solve the question considering the time factor(1-3)min:....According to Legender expression of calculating number of zeros in any factorial could be 5 raised to the power( 1,2,3,4,6) but surely not 5. HENCE APPLYING THIS OBSERVATION in this problem :IT CAN BE DERIVED THAT THE POWER OF 5 SHOULD BE EITHER(1,2,3,4,6)OR MULTIPLE OF (1,2,3,4,6) that is nothing but LCM of these numbers i.e(12) ,powers of multiple of 5 should be completely divisible by(1,2,3,4,6,12) if it is not divisible by all these numbers than that number cannot be the number of zeros in any (n)! – user5918 Jan 20 '11 at 14:04
  • @Isaac/Barry: What if the numbers were larger? Plus you need time for other questions :-). CAT is quite a competitive test (it is for the IIMs in India, which is could get very competitive). – Aryabhata Jan 20 '11 at 15:40
  • @user5918: 105! has 25 zeroes. So your observation in incorrect (if I understood you). Also, please stop using CAPS LOCK. – Aryabhata Jan 20 '11 at 15:41
  • Are there AHSME or AMC 10 questions? – Dhaivat Pandya Dec 04 '11 at 15:41
