Suppose that $\mathbb{Z}$ is a flat $\mathbb{Z}G$-module for a group $G$.
Question: Is $G$ the trivial group ?
Nb. I know that the question can be answered affirmatively if $G$ is finitely generated.
Edit: I think the following lemma solves the problem. I would be grateful if someone could have a look on its proof and give some feedback whether it looks ok. Thanks.
Lemma: Let $R \le S$ be rings with unit such that $S$ is flat as left $R$-module. Then every flat left $S$-module is also flat as left $R$-module.
Now let $G\neq 1$ be any group. If $G$ is abelian then $\mathbb{Z}$ isn't flat by Georges' argument. If $G$ is not abelian, we can find an abelian subgroup $1 \neq H \le G$. Now, if $\mathbb{Z}$ were flat as $\mathbb{Z}G$-module, it would also be flat as $\mathbb{Z}H$-module by the lemma. But we just saw that this isn' true. Hence $\mathbb{Z}$ isn't flat as $\mathbb{Z}G$-module. We have therefore shown:
For a group $G$ the following is equivalent:
  1. $G=1$
  2. $H_i(G,-)=0\,$ for all $i > 0$
  3. $H^i(G,-)=0\,$ for all $i > 0$
Proof of the Lemma: Let $E$ be a flat left $S$-module and let $i: M \to N$ be an embedding of right $R$-modules. We have to show that $i \otimes id_E: M \otimes_R E \to N \otimes_R E$ is also an embedding.
Since $S$ is a flat left $R$-module, tensoring with $S$ from the right yields an embedding $i \otimes id_S: M \otimes_R S\to N \otimes_R S$ of right $S$-modules. Similarly, as $E$ is a flat left $S$-module, we obtain the embedding $$(i \otimes id_S)\otimes id_E: (M \otimes_R S)\otimes_S E \to (N \otimes_R S) \otimes_S E$$ which, by associativity of the tensor product, is equivalent to $$i \otimes (id_S\otimes id_E): M \otimes_R (S\otimes_S E) \to N \otimes_R (S \otimes_S E)$$ which, by the natural isomorphism $S \otimes_S E \cong E$ is equivalent to $$i \otimes id_E: M \otimes_R E \to N \otimes_R E.$$ Hence $i \otimes id_E$ is an embedding and thus $E$ is flat as left $R$-module. QED
Ralph
  • 1,830
    That would make all its homology trivial then? –  Aug 14 '12 at 01:42
  • Yes (in positive degrees). – Ralph Aug 14 '12 at 02:14
  • Sorry I don't see why being flat makes the homologies trivial; this is only if the module is projective (in which case Ralph's last sentence implies that he knows the result). – Chris Gerig Aug 14 '12 at 02:53
    Chris, this is just the definition of flatness!!! – Ralph Aug 14 '12 at 03:27
  • Of course! Completely overlooked the basic construction: $H_n(G;\mathbb{Z})=H_n(F_G)$ where $F$ is a particular exact sequence (projective resolution of $\mathbb{Z}$) and is tensored by $\mathbb{Z}G$, preserving exactness for $F_G$. – Chris Gerig Aug 14 '12 at 08:11
  • Alternatively it's easy to memorize by using the definition $H_i(G,-)=Tor_i^{\mathbb{Z}G}(\mathbb{Z},-)$ and the usual property that an $R$-module $M$ is flat iff $Tor_i^R(M,-)=0$ for $i > 0$. – Ralph Aug 14 '12 at 08:24
  • Ralph your updated-edit is wrong: nontrivial groups $G$ with trivial homology are called acyclic and they do indeed exist. – Chris Gerig Aug 16 '12 at 07:41
  • Oh Chris, always your doubtful comments based on half knowledge. A group is acyclic, if $H_i(G,\mathbb{Z})=0,$ for all $i > 0$ (which is equivalent to $H_i(G,M)=0,$ for all $i > 0$ and all trivial coefficients $M$). In my statement, however, non-trivial coefficients are also concerned. – Ralph Aug 16 '12 at 09:17
Result If $G$ is not perfect (i.e. if $G\neq[G,G]$) , then the $\mathbb Z[G]$-module $\mathbb Z$ is not flat.
Example If $G\neq 0$ is commutative, then the $\mathbb Z[G]$-module $\mathbb Z$ is not flat
Proof
1) If $I\subset A$ is an ideal of a ring and $A/I$ is $A$-flat, then $I/I^2=0$
Indeed, tensor the injection $0\to I\to A$ with $A/I$ and obtain the injection $0\to I/I^2\to A/I: [i]\mapsto \bar i$ .
This last map is zero and can only be injective if $I/I^2=0$
2) In our case $A=\mathbb Z[G]$ and $I$ is the augmentation ideal consisting of the $\sum a_gg$ with $\sum a_g=0$.
Weibel's Introduction to Homological Algebra assures us (in an exercise page 164) that $I/I^2=G/[G,G]$.
Hence flatness of $\mathbb Z$ implies $I/I^2=0$ by 1) which in turn forces $G=[G,G]$ : the Result follows.
  • Thanks for your reply (I think your proof can be shortened by simply noting that $H_1(G,\mathbb{Z})=G_{ab}$). So a counter-example to the question must be not f.g. and not perfect. – Ralph Aug 14 '12 at 08:42
    Dear Ralph: well, maybe, but as a matter of personal taste I would prefer not to invoke homology theory and give proofs from first principles. Amusingly you confirm my point of view that you only really have integrated a result if you find all the presentations by others unsatisfying! – Georges Elencwajg Aug 14 '12 at 08:54
