I want to prove that if $X$ is a metric space and has a dense countable subset, then it has a countable basis. I know that every metric space is first countable, but I can't continue. Thanks for your help.
Asked
Active
Viewed 907 times
See also http://math.stackexchange.com/q/1810581/4280 – Henno Brandsma Jun 10 '16 at 20:58
Try balls of radius $1/m$ centred at the points $x_n$ of your dense countable subset.
Edit: to see how this works, consider a ball of radius $r$ around any point $p$. What conditions on $m$ and $x_n$ would guarantee that the ball of radius $1/m$ around $x_n$ contains $p$ and is contained in this ball?
Robert Israel
- 448,999
The matter is how can I show this is a basis? How does it cover all the X? – math Jun 10 '16 at 16:51
Try to find a situation where it doesn't work. Maybe you'll see how it works in the process. – Anon Jun 10 '16 at 16:54
Hint: Well, you have a countable collection of points to use as centers of balls, and you have a countable basis $\{B(x,\tfrac1n):n\in\mathbb N\}$ at each such point $x$, so...
MPW
- 43,638
Well, take a dense subset of $D\subset X$ and then the metric guarantees you a countable neighbourhood basis at every point of $D$. A countable union of countable sets is again countable. Check that this is enough.
cQQkie
- 449
- 1
- 3
- 12
