I need to show the following:
$f:M\to N\times N$ is continuous and $\Delta = \{(y,y):y\in N\}\subset N\times N$ then $f^{-1}(N\times N-\Delta)$ is an union of open balls in $M$
But I have no idea of which things I must assume. I know that if I can prove that its open, then its automatically an union of open balls. However, I've read here that it suffices to show that $N\times N-\Delta$ is open. Is this it? And why does it follows that the inverse is open?
An equivalent definition of continuity is that the inverse image of every open set is open. In fact, many people would take that as the true definition of continuity!
So if $N\times N-\Delta$ is open then the result follows.
Now it is open if and only if $\Delta$ is closed. The latter is easy to show. Take a sequence in it that converges and show the limit is in it too.
Mark Joshi
  • 5,604
