Does anyone know a formula for the derivative $$\frac{d^k}{dx^k}\left(f(x)^k\right)$$ where $k$ is some positive integer?
I started trying to work it out but it got messy.
Apply Faà di Bruno's formula to get $$\frac{d^n}{dx^n}(g(x)^n)=\sum \frac{n!^2}{m_1!\dots m_n!(n-\sum_{j=1}^nm_j)!}g(x)^{n-\sum_{j=1}^nm_j}\prod_{j=1}^n\left(\frac{g^{(j)}(x)}{j!}\right)^{m_j},$$ where the sum is taken over the $n$-uples $(m_1,\dots,m_n)$ of integer satisfying $\sum_{k=1}^nkm_k=n$.
(I changed the notations to be conform with the link)
As a probable illustration of Davide Giraudo's powerful answer (+1) you may get the following result :
$ \begin{array} {r|cccccccc} k\\ \hline 1&1f'\\ 2&2f''f&2f'^2\\ 3&3f'''f^2&18f''ff'&6f'^3\\ 4&4f''''f^3&48f'''f^2f'&36f''^2f^2&144f'^2f''f&24f'^4\\ 5&5f'''''f^4&100f''''f^3f'&200f'''f^3f''&600 f'''f^2f'^2&900f^2f'f''^2&1200ff'^3f''&120f'^5\\ \end{array} $
This triangle appears as sequence OEIS A049009 titled "Number of functions from a set to itself such that the sizes of the pre-images of the individual elements in the range form the n-th partition in Abramowitz and Stegun order"
In fact this is a product of multinomials coefficients and 'number of multisets associated with least integer of each prime signature' (the second one shifted by $2$ I think). Perhaps that this will help a little to interpret Davide's general answer (I have not much hope for further simplification...)
Hoping it helped anyway,
As a reformulation of Davide's answer, the $k$-th derivative of $f(x)^k$ is most easily expressed using the partial Bell polynomials:
$$\frac{\mathrm d^k}{\mathrm dx^k}f(x)^k=\sum_{j=1}^k j!\binom{k}{j} f(x)^{k-j} \mathrm{B}_{k,j}(f^\prime(x),f^{\prime\prime}(x),\cdots,f^{(k-j+1)}(x))$$
This construction is most convenient if the computing environment you are using supports partial Bell polynomials (e.g. Mathematica).
After Raymond's explication of Davide's Faa di Bruno-formula I decomposed it in an even more memorizable form. Example k=4
$$ \begin{eqnarray} {(f^4)^{(4)}\over 4! \cdot 4! } &=&
{{ f^{(0)}\over 0!} { f^{(0)}\over 0!}{ f^{(0)}\over 0!} \over 3! }{{ f^{(4)}\over 4!} \over 1! } \\ \\
&+ & {{ f^{(0)}\over 0!} { f^{(0)}\over 0!} \over 2! }{{ f^{(1)}\over 1!} \over 1! } {{ f^{(3)}\over 3!} \over 1! } \\ \\
&+ & {{ f^{(0)}\over 0!} { f^{(0)}\over 0!} \over 2! }{{ f^{(2)}\over 2!}{ f^{(2)}\over 2!} \over 2! }
&+ & {{ f^{(0)}\over 0!} \over 1! } {{ f^{(1)}\over 1!} { f^{(1)}\over 1!} \over 2! }{{ f^{(2)}\over 2!} \over 1! } \\ \\
&+ & {{ f^{(1)}\over 1!} { f^{(1)}\over 1!} { f^{(1)}\over 1!} { f^{(1)}\over 1!}\over 4! } \\ \\
\end{eqnarray} $$
The key for that decomposition is, that for some k we need k factors in each summand. Then the sum of all derivation-indices (with their multiplicity!) must also equal k. A j-fold multiplicity of a factor must be compensated by a j! in the denominator.
If we write
$\displaystyle [k]= { f^{(k)}\over k! } $ and $ \displaystyle [k \times j] = { [k]^j \over j!} $ we can denote it even more compact:
$$ \begin{eqnarray}{(f^4)^{(4)} \over 4!4! }&=& [0 \times 3][4 \times 1] \\ &+& [0 \times 2][1 \times 1][3 \times 1] \\ &+& [0 \times 2][2 \times 2] + [0 \times 1][1 \times 2][2 \times 1] \\
&+&[1 \times 4] \end{eqnarray}
$$ where, if we take the brackets as products and the terms as sums then each term has the sum k. It is a simple mechanic to write down the terms by hand for some small k, even for $k=10$ or so this should be doable with paper and pen.
