For a given non-constant polynomial $f(x)$ with integer coefficients, how many solutions are there to $f(x)\equiv 0 \mod(n)$ where $n$ is composite?
Is there a general way to determine the number of incongruent solutions modulo $n$?
My first idea is that we can of course break $n$ into its prime power factorization and look at $f(x)\equiv 0 \mod(p_{i}^{e_{i}})$ where $(p_{i}^{e_{i}})$ appears as a prime power factor in $n$.
Here's where I start to become confused, if $f(x)=x$ then the Chinese remainder theorem tells us that the solution is unique modulo $n$, but if $f(x)$ is non-constant and non-linear then we need to use the lifting method to solve $f(x)\equiv 0$ for each $\mod(p_{i}^{e_{i}})$ - but so far the method tells us nothing about the number of solutions.
I presume I am not incorrect in saying that the number of incongruent solutions to $f(x)\equiv \mod(p_{i}^{e_{i}})$ is at most $min(deg(f), p_{i}^{e_{i}})$, but is there a general way to determine precisely how many solutions are there?
  • If $f(n)\equiv 0\pmod4$ has two solutions, and $f(n)\equiv 0\pmod{25}$ has six solutions, then $f(n)\equiv 0\pmod{100}$ has twelve solutions. Is that what you're asking? – Arthur May 05 '16 at 07:37
  • Essentially yes, but why's that? – user162089 May 05 '16 at 07:42
    @user162089 because of the Chinese Remainder Theorem – Hagen von Eitzen May 05 '16 at 07:48
  • Because every pair $(a,b)$ with $a$ being modulo four and $b$ being modulo $25$ gives a unique residue class $c$ modulo $100$. Also, this pairing respects polynomials, so $(f(a),f(b))$ corresponds to $f(c)$. There are two $a$ for which the polynomial is zero, and six $b$, which makes twelve pairs of solutions. – Arthur May 05 '16 at 07:55
First factor $m$ to powers of primes. $$N(m) = PI\ N(p^a)$$ $N$ is number of roots. This is by CRT.
Then for each prime factor p of m, a polynomial $P(x)$ can be reduced to $P'(x)$ with degree $<= p$. If $P'(x)$ is a factor of $(x^p - x) \mod p$ (after dividing, the remainder is multiple of $p$), then it has exactly $n$ roots where $n$ is degree of $P'(x)$.
From $p$ to $p^a$, it's Hensel's Lemma.
dantopa
  • 10,342
