Suppose $u$ is a solution of the heat equation with the property that $|\int\limits_{-\infty}^{\infty}u(x,0)dx| < \infty$, and $u_{x}(x,t) \rightarrow 0$ as $x \rightarrow \pm \infty$. Then integrating the PDE, we find
$$\frac{d}{dt}\int\limits_{-\infty}^{\infty}u(x,t)dx = 0 \quad (1)$$
so that thet total heat energy is conserved:
$$\int\limits_{-\infty}^{\infty}u(x,t)dx = \text{ constant.} \quad (2)$$
Could someone explain how to get from the initial conditions to equation $(1)$?
I was thinking to use Leibniz integral rule, but got stuck at the following stage:
$$\frac{d}{dt}\int\limits_{-\infty}^{\infty}u(x,t)dx = \int\limits_{-\infty}^{\infty}u_t(x,t)dx \quad + \quad 0$$
as I see no mention on how the above should behave at the boundaries.
The notes can be found online at IITD notes on The Heat Equation.
  • There's no need to differentiate the integrand: Defining $f(t)\equiv \int_{-\infty}^\infty u(x,t),dx$, we have $f'(t)=0\implies f(t)=\text{constant}$. The initial conditions only enter if one wants to determine the total energy, not in showing that it's constant. – Semiclassical May 03 '16 at 23:37
  • Why is $f^{\prime}(t) = 0$ ? Could $u(x,t)$ not be a more complex function where after integrating out $x$ one would be left with a function which is not a constant in terms of $t$? – Gabor Bakos May 03 '16 at 23:44
  • Your equation (1) says precisely that $\dfrac{d}{dt}f(t)=f'(t)=0$. – Semiclassical May 04 '16 at 00:06
  • Why does one need the finiteness assumption? – mavavilj Oct 30 '17 at 12:51
$\int_{-\infty}^\infty u_t(x,t) dx = \int_{-\infty}^\infty u_{xx}(x,t) dx = u_x(\infty,t)-u_x(-\infty,t)$. Now you use your decay condition. (The more interesting question is to prove that decay condition a priori.)
Ian
  • 101,645
  • First of all, thank you for the answer, I should have realised that I need to use the fact that it is a heat equation... Secondly, by decay condition do you mean: $u_{x}(x,t) \rightarrow 0$ as $x \rightarrow \pm \infty$? – Gabor Bakos May 03 '16 at 23:51
  • @GaborBakos Yes. – Ian May 03 '16 at 23:52
