I tried $\tan(x)$, and $\log(x)$, but seems it does not work, so I wonder is there a bijection or not?
Consider that $$ [0,\infty) = \{0\} \cup (0,1) \cup \{1\} \cup (1,2) \cup \{2\} \cup \cdots $$ and $$ (0,1) = (0,1/2) \cup \{1/2\} \cup (1/2,3/4) \cup \{3/4\} \cup (3/4, 7/8) \cup \{7/8\} \cup \cdots $$
So we can make a bijection between then so that $0$ maps to $1/2$, $1$ maps to $3/4$, $2$ maps to $7/8$, etc., and the interval $(0,1)$ maps to the interval $(0,1/2)$ and the interval $(1,2)$ maps to the interval $(1/2,3/4)$, etc.
You cannot find a bijection with a single continuous function, because of topological reasons which are more advanced than the construction just described. In particular, $[0,\infty) \setminus \{0\}$ is connected but $(0,1)$ minus any point is disconnected, and the image of a connected set under a continuous map is connected.
- 81,604
$$ f(x) = \begin{cases} \dfrac x {x+1} & \text{if } x\notin\{0,1,2,3,\ldots\}, \\[8pt] \dfrac{x+1}{x+2} & \text{if } x\in\{0,1,2,3,\ldots\}. \end{cases} $$ $f : [0,\infty) \to (0,1)$ is one-to-one and onto.
@user391135 The idea is that if you just have $g(x)=\dfrac x{x+1},$ that's a bijection from $[0,\infty)$ to $[0,1),$ but then you modify this function as follows: $$ \begin{array}c f(g^{-1}(0)) = 1/2 \ {} \ f(g^{-1}(1/2)) = 2/3 \ {} \ f(g^{-1}(2/3)) = 3/4 \ {} \ f(g^{-1}(3/4)) = 4/5 \ {} \ \vdots \end{array} $$ Think about that pattern in order to see why this is bijective. $\qquad$ – Michael Hardy May 04 '20 at 19:06
Yes. You can find an injection from $(0,1)$ to $[0,\infty)$ by using $f(x) = 1/x$. You can find an injection from $[0,\infty)$ to $(0,1)$ by $\frac{1}{10} \arctan(x)+\frac{1}{10}$.
Since you have injections from each set to the other, there exists a bijection between them (via cantor-schroder-bernstein).
- 19,390
No. I'm showing that $f(x) = 1/x$ is an injection not a bijection (i.e. we do not require the function to be onto), and similiarly for the use of arctan. By invoking cantor-schroder-bernstein, if you have an injection both ways, there exists a bijection. – Batman May 03 '16 at 02:09
For a bijection, $f:[0,1) \to (0,1)$, you can use something similar to what user "Did" constructed here (link fixed)
– MathematicsStudent1122 May 03 '16 at 01:54
