Evaluate $\tan^{2}(20^{\circ}) + \tan^{2}(40^{\circ}) + \tan^{2}(80^{\circ})$.
Can anyone help me with this? Thank You!
Method $1:$
We know $$ \tan^2A=\frac{1-\cos2A}{1+\cos2A} $$
Let us find the cubic equation whose roots are $\cos40^\circ, \cos80^\circ, \cos160^\circ$.
As $\cos(3\cdot 40^{\circ})=\cos120^{\circ}=-\frac{1}{2}$ or, $4\cos^340^{\circ} -3\cos40^{\circ}=-\frac{1}{2}$.
So, $\cos40^{\circ} $ is a root of $$ 4x^3-3x=-\frac12\implies 8x^3-6x+1=0 $$ Similarly, $\cos80^{\circ},\cos160^{\circ}$ are also the roots of $ 8x^3-6x+1=0 $ (Another derivation can be found at the bottom)
If we replace $x$ with $\dfrac{1-y}{1+y}$, the sum of the roots of the new equation in $y$ will give us the desired value.
Method $2:$ (Inspired by Zarrax's answer)
Observe that $\tan(3\cdot20^\circ)=\tan60^\circ=\sqrt3$
$\tan(3\cdot40^\circ)=\tan120^\circ=\tan(180^\circ-60^\circ)=-\tan60^\circ=-\sqrt3$ $\iff \tan\{3(-40^\circ)\}=\sqrt3$
and $\tan(3\cdot80^\circ)=\tan240^\circ=\tan(180^\circ+60^\circ)=\tan60^\circ=\sqrt3$
$$\text{As }\tan3\theta=\frac{3\tan\theta-\tan^3\theta}{1-3\tan^2\theta}$$
$$\text{the roots of the equation } t^3-3\sqrt3t^2-3t+\sqrt3=0 (\text{ Putting } \tan3\theta=\sqrt3)$$ will be $\tan20^\circ,\tan(-40^\circ)=-\tan40^\circ, \tan80^\circ$
Using Vieta's formulas, $$\tan20^\circ+(-\tan40^\circ)+\tan80^\circ=\frac{3\sqrt3}1$$
$$\text{and } \tan20^\circ(-\tan40^\circ)+\tan20^\circ\cdot\tan80^\circ+\tan80^\circ(-\tan40^\circ)=-3$$
$$\text{So,}\tan^220^\circ+\tan^240^\circ+\tan^280^\circ =(\tan20^\circ)^2+(-\tan40^\circ)^2+(\tan80^\circ)^2$$ $$=\{\tan20^\circ+(-\tan40^\circ)+\tan80^\circ\}^2$$ $$-2\{\tan20^\circ(-\tan40^\circ)+\tan20^\circ\cdot\tan80^\circ+\tan80^\circ(-\tan40^\circ)\}$$
$$=(3\sqrt3)^2-2(-3)=33$$
Applying the following identities,
$$\begin{align*}
\cos 2A+\cos 2B&=2\cos(A-B)(A+B),\\
\sin2A&=2\sin A\cos A,\\
2\cos A\cos B&=\cos(A-B)+\cos(A+B)
\end{align*}$$
we get
$$\begin{align*}
\cos40^{\circ} + \cos80^{\circ} + \cos160^{\circ}&=0\\
\cos40^{\circ}\cos80^{\circ} + \cos80^{\circ}\cos160^{\circ} + \cos160^{\circ}\cos40^{\circ}&=-\frac{3}{4}\\
\end{align*}$$
$$\text{ and } \cos40^{\circ} \cos80^{\circ} \cos160^{\circ}=-\frac{1}{8}$$
Then the cubic equation whose roots are $\cos40^{\circ}, \cos80^{\circ}, \cos160^{\circ}$ is $$ x^3-\frac{3}{4}x+\frac{1}{8}=0 $$
In $(7)$ from this answer, it is shown that $$ \sum_{l=1}^n\tan^2\left(\frac{\pi l}{2n+1}\right)=n(2n+1) $$ In this case, $n=4$ and you're missing $l=3$. $\tan^2(60^\circ)=3$, so the sum would be $$ 36-3=33 $$
Notice that for $\theta = 20, 40,$ and $80$ degrees you have $\tan^2(3\theta) = 3$. The tangent triple angle formula, which you can get from the tangent angle addition formula, says that $$\tan(3\theta) = {3\tan(\theta) - \tan^3(\theta) \over 1 - 3 \tan^2(\theta)}$$ So the equation $\tan^2(3\theta) = 3$ can be expressed as $$(3\tan(\theta) - \tan^3(\theta))^2 = 3(1 - 3 \tan^2(\theta))^2$$ After a little algebra, this becomes the following, where $x = \tan(\theta)$. $$x^6 - 33x^4 + 27x^2 - 3 = 0$$ By the above, this has roots $x = \tan(20^\circ), \tan(40^\circ),$ and $\tan(80^\circ)$. Since $x$ only appears to even powers here, the other roots must be $x = -\tan(20^\circ), -\tan(40^\circ),$ and $-\tan(80^\circ)$. The sum of the squares of all six roots is thus given by $2(\tan^2(20^\circ) + \tan^2(40^\circ) + \tan^2(80^\circ))$. However, if we write these roots as $r_1,...,r_6$, then we also have $$\sum_i r_i^2 = \left(\sum_i r_i\right)^2 - 2\sum_{i < j} r_ir_j$$ But $\sum_i r_i$ is the coefficient of $x^5$ in the above equation, namely zero, and $\sum_{i < j} r_ir_j$ is the coefficient of $x^4$, namely $-33$. So you get $$2(\tan^2(20^\circ) + \tan^2(40^\circ) + \tan^2(80^\circ)) = -2\times-33$$ So we conclude that $$\tan^2(20^\circ) + \tan^2(40^\circ) + \tan^2(80^\circ) = 33$$
Here's a linear algebraic route: from this answer, we find that the eigenvalues of the $4\times4$ min-matrix
$$\mathbf M=\begin{pmatrix} 1 & 1 & 1 & 1 \\ 1 & 2 & 2 & 2 \\ 1 & 2 & 3 & 3 \\ 1 & 2 & 3 & 4 \end{pmatrix}$$
are $\lambda_k=\dfrac14\sec^2\left(\dfrac{k\pi}{9}\right)$ for $k=1,\dots,4$. From this, we have that the eigenvalues of $4\mathbf M-\mathbf I$ are $\nu_k=\tan^2\left(\dfrac{k\pi}{9}\right)$, and since the sum of the eigenvalues is equal to the trace of the matrix,
$$\tan^2\frac{\pi}{9}+\tan^2\frac{2\pi}{9}+\tan^2\frac{4\pi}{9}=4(1+2+3+4)-4-\tan^2\frac{\pi}{3}=33$$
Since $$1+\tan^2 \alpha=\frac 1{\cos^2\alpha}=\frac 2{1+\cos 2\alpha},$$
$$\tan ^{2}20^{\circ}+\tan ^{2}40^{\circ}+\tan ^{2}80^{\circ}+3= \frac 2{1+\cos 40^{\circ}}+\frac 2{1+\cos 80^{\circ}}+\frac 2{1+\cos 160^{\circ}}.$$
Reducing the last sum to a common denominator and using the equalities from the appendix of the answer by lab bhattacharjee, we obtain $36$.
Using the formula $ \cos 3 \theta = 4 \cos ^ { 3 } \theta - 3\cos \theta,$ we have
$\qquad\qquad 4 \cos ^ { 3 } 40 ^ { \circ } - 3 \cos 40 ^ { \circ }$ $\left. { = \cos 120 ^ { \circ } } { = - \frac { 1 } { 2 } } \right. $
$\qquad \Rightarrow \quad 8 \cos ^ { 3 } 40 ^ { \circ } - 6 \cos 40 ^ { \circ } + 1 = 0 $$ \quad \Rightarrow \quad \cos 40 ^ { \circ } $ is a root of $8 x ^ { 3 } - 6 x + 1 = 0 \cdots (1) $
$\text{Similarly, }$$\cos 80 ^ { \circ }\text{and}\cos 160^{ \circ }\text{are also the roots of (1).}$$\text{Now we are going to transform (1) by $ y=x^2 $ into another equation (2) whose roots are } $$\cos ^2 40 ^ { \circ }, \cos ^2 80 ^ { \circ } \text{ and } \cos ^2160^ { \circ }\tag*{}. $
$\text{From (1),} -1= x(8x^2–6). \text{ Squaring both sides, we have }$$1=x^2(8x^2–6)^2 \text{and hence }64y^3–96y^2+36y-1=0 \tag*{(2)} \\$$\text{whose roots are }\cos ^2 40 ^ { \circ }, \cos ^2 80 ^ { \circ } \text{and }\cos ^2 20^ { \circ }. $ However, in order to get the sum of squares of tangents of $20^{\circ}, 40^{\circ} \text{and }80^{\circ},$ we need their corresponding secant squares. One more transformation $z=\frac{1}{y}$ is introduced to get another equation (3): $$\quad z ^ { 3 } - 36 z^2 + 96 z - 64 = 0, $$ $\text{whose roots are }\sec ^ { 2 } 20 ^ { \circ } , \sec ^ { 2 }40 ^ { \circ } \textrm{and } \sec ^ { 2 } 80 ^ { \circ }.$
$\therefore \tan ^ { 2 } 20 ^ { \circ } + \tan ^ { 2 } 40 ^ { \circ } + \tan ^ { 2 } 80 ^ { \circ } + 3$
$=\tan ^ { 2 } 20^ { \circ } +1 + \tan ^ { 2 } 40 ^ { \circ } +1 + \tan ^ { 2 } 80 ^ { \circ } + 1$
$= \sec ^ { 2 } 20 ^ { \circ } + \sec ^ { 2 } 40 ^ { \circ } + \sec ^ { 2 } 80 ^ { \circ }$
$=36$
Hence $\boxed{\tan ^ { 2 } 20 ^ { \circ } + \tan ^ { 2 } 4 0 ^ { \circ } + \tan ^ { 2 } 80 ^ { \circ } = 33.}$
