I would like to know the divisibility tests for 13, 16, 17, 19. I also would appreciate the proof for the divisibility test done. Please oblige!
Rgds Jayanth
Rgds Jayanth
Test for divisibility by 13. Add four times the last digit to the remaining leading truncated number. If the result is divisible by 13, then so was the first number. Apply this rule over and over again as necessary. Example: $50661\rightarrow5066+4=5070\rightarrow507+0=507\rightarrow50+28=78$ and $78$ is $6\times13$, so $50661$ is divisible by $13$.
Test for divisibility by 17. Subtract five times the last digit from the remaining leading truncated number. If the result is divisible by 17, then so was the first number. Apply this rule over and over again as necessary. Example: $3978\rightarrow397-5\times8=357\rightarrow35-5\times7=0.$ So $3978$ is divisible by $17$.
Test for divisibility by 19. Add two times the last digit to the remaining leading truncated number. If the result is divisible by 19, then so was the first number. Apply this rule over and over again as necessary. EG: $101156\rightarrow 10115+2\times6=10127\rightarrow1012+2\times7=1026\rightarrow102+2\times6=114$ and $114=6\times19$, so $101156$ is divisible by 19.
NOTE: I found it from some blog.
