I would like to know how Stone-Čech compactification works with simple examples, like $(0,1)$, $\mathbb{R}$, and $B_r(0)$ (the open ball of $R^2)$. I've studied the one-point compactification and this is way more difficult to understand. All the texts I've found till now start immediately with functions and closure of functions. If somebody could give me some "visible" ideas, I would bear those in mind and understanding the theory would be a little easier.
Asked
Active
Viewed 1,126 times
12
What is $D^2$?${}$ – Martin Sleziak Jul 17 '12 at 14:47
2You can find something about the cardinality of Stone–Čech compactification of some spaces here: Stone–Čech compactification of $\mathbb{N}, \mathbb{Q}$ and $\mathbb{R}$. But I'm not sure whether this is what you're asking. – Martin Sleziak Jul 17 '12 at 14:50
The standard disk of a plane, a should have add "open". You're right, that is very confusing. I'll change it. – Temitope.A Jul 17 '12 at 14:51
14
There are spaces like $[0,\omega_1)$ with the order topology where the Stone-Cech compactification is the same as the one-point compactification.
On the other hand, the Stone-Cech compactification of the natural numbers $\mathbb N$ has cardinality $2^{\mathfrak c}$. So the answers depends a lot on the space.
azarel
- 13,120
