Perhaps look at this page for an example how to set up the Neyman-Pearson criterion.
Maybe it will help if I illustrate the idea with a specific numerical example. Suppose $\lambda_0 = 3$ and $\lambda_1 = 10.$ Also, for simplicity, suppose we have a single observation $X.$ It makes sense to reject $H_0$ for "large" values of $X$ and
to accept for "small" values. The task is to find a critical value $c$ to
separate "large" from "small."
Here are partial PDF tables for $Pois(3)$ and $Pois(10)$ from R statistical software.
i = 0:10; pdf.0 = dpois(i,3); pdf.1 = dpois(i,10); ratio=pdf.0/pdf.1
round(cbind(i, pdf.0, pdf.1, ratio),3)
## i pdf.0 pdf.1 ratio
## 0 0.050 0.000 1096.633
## 1 0.149 0.000 328.990
## 2 0.224 0.002 98.697
## 3 0.224 0.008 29.609
## 4 0.168 0.019 8.883
## 5 0.101 0.038 2.665
## 6 0.050 0.063 0.799
## 7 0.022 0.090 0.240
## 8 0.008 0.113 0.072
## 9 0.003 0.125 0.022
## 10 0.001 0.125 0.006
If we want to test at the 5% level, we need to look in the right-hand tail of the distribution $Pois(3)$ to accumulate about 5% (without going over). It is
obvious that we can't use $c = 5.5$ because $P(X > 5.5|\lambda=3) > .05.$
But maybe we can use $c = 6.5.$ We find that $\alpha = P(X > 6.5|\lambda=3) .0335 < .05.$
So we use $c$ as the critical value. Then the rejection region is
$\{X > 6.5\}$ and the acceptance region is $\{X < 6.5\}.$
Then the power of the test (probability of rejecting when $H_1$ is true)
is $P(X > 6.5 | \lambda=10) \approx .87.$
1 - ppois(6.5, 10)
## 0.8698586
It seems clear from looking at the table above that no choice of the rejection region with $\alpha < .05$
could have a larger power. We have "spent" our roughly 5% probability in
the $H_0$ column of the table in a way that makes the probability of
the rejection region in the $H_1$ column as large as possible (hence, the
ratio is as small as possible).
By looking at the ratio of probabilities in the two columns, that optimal choice is what the Neyman-Pearson Lemma ensures.
More generally, notice that $\sum_{i=1}^n X_i = Y \sim Pois(n\lambda).$
so, as you guessed, it does not matter whether we express the critical value for $n$
observations in terms of $Y$ or $\bar X_n = Y/n.$
You might
try writing the ratio for the case $n = 1$ first.
\bar X_n
. Also,\overline X_n
for $\overline X_n$. Also also, use\ln k
for $\ln k$. – Em. Mar 28 '16 at 18:57
