At the moment I'm studying constrained optimization. Recently we had a lecture concerning dual problems. I have a few questions regarding this.
The primal problem is given as \begin{align} \min_x \quad & \frac{1}{2} x^THx+g^Tx \\ \text{s.t.} \quad & A^Tx = b . \end{align} The Lagrange dual program of the equality constrained QP is given as \begin{align} \max_{x,\lambda} & \qquad - \frac{1}{2} x^THx+b^T \lambda, \\ \text{s.t} & \qquad Hx+g-A\lambda = 0. \\ \end{align} It's assumed that the matrix H is positive definite.
My questions are as follows.
  1. How is this maximization problem derived?
  2. What are the optimality conditions for the dual problem and how are they related to the primal problem?
  3. When does the primal and dual problem have the same solution?
  4. Can one use KKT for the solution of this problem?
  5. How are the variables in the primal and dual problem related in general?
  6. What are the advantage of solving the dual instead of the primal problem?
I have a few suggestions myself.
Q1: I've read that we define the dual objective as the infimum of the Lagrange, that is $q(\lambda) = \inf_x L(x, \lambda)$. The dual problem is then the maximization of q. However I'm in doubt about the constraints in the dual problem.
Q2: Don't know.
Q3: Is it when the primal problem is strictly convex (meaning a positive definite hessian in the primal objective function)?
Q4: Don't know. Guess it depends on the optimality conditions somehow.
Q5: Don't know.
Q6: Don't know.
ViktorStein
  • 4,838
ANYN11
  • 365
I'll assume that $H$ is symmetric positive definite (as stated in the question).
The Lagrangian is \begin{align} L(x,\lambda) &= \frac12 x^T Hx + g^T x + \lambda^T (A^Tx - b) \\ &= \frac12 x^T H x+ x^T (A \lambda + g) - \lambda^T b. \end{align} The dual function is \begin{align} g(\lambda) &= \inf_x \, L(x,\lambda) \\ &= -\frac12 (A \lambda + g)^T H^{-1} (A \lambda + g) - \lambda^T b. \end{align}
The dual problem is to maximize $g(\lambda)$ (with no constraints on $\lambda$). Is this equivalent to the dual problem given in the question? From the constraint $Hx + g - A \lambda = 0$, it follows that $x = H^{-1}(A \lambda - g)$. Plugging into the objective function, the stated dual problem reduces to \begin{align} \text{maximize} & \quad -\frac12 (A \lambda - g)^T H^{-1}(A \lambda - g) + b^T \lambda \\ \text{subject to} & \quad \lambda \geq 0. \end{align} This is similar to the dual problem I derived, except that we have $-g$ in place of $g$ and we have an extra constraint $\lambda \geq 0$.
It seems like the dual problem given in the question is wrong.
littleO
  • 51,938
  • You are right. The constraint on lambda is not correct. I'll delete it. Further I've come up with some answers for some of the question myself. Thanks for your reply though :) – ANYN11 Mar 29 '16 at 16:12
  • @littleO I'm working on a problem similar to this, where I have posted a question here: https://math.stackexchange.com/questions/2571031/need-help-setting-up-and-solving-dual-problem Would you be willing and/or able to take a look and possibly help me out? Thanks so much! :) –  Dec 17 '17 at 21:53
  • @littleO: why is $\lambda\geq0$ needed? – jjjjjj Jul 25 '21 at 22:27
  • @jjjjjj What I was writing down there was the dual problem which was stated in a previous version of the question [the question has since been edited], and I was commenting that the "stated" dual problem seems to be wrong, because indeed the constraint $\lambda \geq 0$ should not be there. This answer I posted only made sense in response to a previous version of the question. – littleO Jul 25 '21 at 23:23
  • gotcha, thanks! – jjjjjj Jul 25 '21 at 23:24
I searched some literature. It appears this duality is from the paper Duality in Quadratic Programming by W. S. Dorn. Here is a link to that paper: https://www.ams.org/journals/qam/1960-18-02/S0033-569X-1960-0112751-2/S0033-569X-1960-0112751-2.pdf.
