For a real valued $m$ by $n$ matrix $M$ with $m<n$, why is the following true?
$$\det(I+MM^T) = \det(I+M^TM)\;?$$
To me this seems counter-intuitive as $\det(M^TM) = 0$.
This is an example of Sylvester's determinant law which states that for an $m\times n$ matrix $A$ and an $n\times m$ matrix $B$, $\operatorname{det}(I_m + AB) = \operatorname{det}(I_n + BA)$. In your case, $A = M$ and $B = M^T$.
  • Thank you. Could you explain why adding the identity makes such a difference? It certainly isn't true without this addition. –  Mar 18 '16 at 16:17
    @Lembik One explanation is this. It's almost true. Recall that if $m=n$, it's certainly true that $\det(MM^T)=\det(M^TM)$. With $m<n$, it is still true if $M$ is rank deficient, since both $MM^T$ and $M^TM$ are singular. It fails for $m<n$ only when $M$ is full-rank, as $M^TM$ is necessarily singular while $MM^T$ is not. However as user251257 pointed out, they still have the same non-zero eigenvalues. Now, recall that adding an identity matrix increments each eigenvalue by 1, and that the determinant is the product of all eigenvalues. It follows that both products equal. – syeh_106 Mar 19 '16 at 04:46
using the SVD decomposition : $M = U S V^*, M^* = V S^* U^*$,
$$I + M M^* = U(SS^* +I)U^*, \qquad I + M^* M = V (S S^* +I) V^*$$
and $det(V A) = det(A) = det(A V)$ for any unitary matrix $V$, hence :
$$det(I+MM^* ) = det(I+M^* M) = det(I+S S^* )$$
if $M$ is real, then $M^* = M^T$ and you get what you asked.
reuns
  • 77,999
