15
Given a finite dimensional inner-product-space $(V,\langle\;,\rangle)$ and an endomorphism $A\in\mathrm{End}(V)$ we can define its adjoint $A^*$ as the only endomorphism such that $\langle Ax, y\rangle=\langle x, A^*y\rangle $ for all $x,y\in V$.
While all of this lets us prove some stuff about unitary, normal and hermitian matrices, I'd like to know if there's some other motivation behind its introduction (Is there a geometric interpretation? Any other algebraic remark?)
Arturo Magidin
  • 398,050
Here is an algebraic approach to adjoint operators. Let us strip away the existence of an inner product and instead take two vector spaces $V$ and $W$. Furthermore, let $V^*$ and $W^*$ be the linear duals of $V$ and $W$, that is, the collection of linear maps $V\to k$ and $W\to k$, where $k$ is the base field. If you're working over $\mathbb R$ or $\mathbb C$, or some other topological field, you might want to work with continuous linear maps between topological vector spaces.
Given a linear operator $A: V\to W$, we can define a dual map $A^*: W^* \to V^*$ by $(A^*(\phi))(v)=\phi(A(v))$. It is straight forward to verify that this gives a well defined linear map between the vector spaces. This dual map is the adjoint of $A$. For most sensible choices of dual topologies, this map should also be continuous.
The question is, how does this relate to what you are doing with inner products? Giving an inner product on $V$ is the same as giving an isomorphism between $V$ and $V^*$ as follows:
Given an inner product, $\langle x, y \rangle$, we can define an isomorphism $V\to V^*$ via $x\mapsto \langle x, - \rangle$. This will be an isomorphism by nondegeneracy. Similarly, given an isomorphism $\phi:V\to V^*$, we can define an inner product by $\langle x,y\rangle =\phi(x)(y)$. The "inner products" coming from isomorphisms will not in general be symmetric, and so they are better called bilinear forms, but we don't need to concern ourselves with this difference.
So let $\langle x,y \rangle$ be an inner product on $V$, and let $\varphi$ be the corresponding isomorphism $\varphi:V\to V^*$ defined above. Then given $A:V\to V$, we have a dual map $A^*:V^* \to V^*$. However, we can use our isomorphism to define a different dual map (also denoted $A^*$, but which we will denote by $A^{\dagger}$ to prevent confusion) by $A^{\dagger}(v)=\varphi^{-1}(A^*\phi(v))$. This is the adjoint that you are using.
Let us see why. In what follows, $x\in V, f\in V^*$. Note that $\langle x, \varphi^{-1} f \rangle = f(x)$ and so we have
$$ \langle Ax, \varphi^{-1}f \rangle = f(Ax)=(A^*f)(x)=\langle x, \varphi^{-1}(A^* f) \rangle $$
Now, let $y=\varphi^{-1}f$ so that $\varphi(y)=f$ Then we can rewrite the first and last terms of the above equality as
$$\langle Ax, y \rangle = \langle x, \varphi^{-1}(A^* \phi(y)) \rangle = \langle x, A^{\dagger}y \rangle $$
Lemon
  • 12,664
Aaron
  • 24,207
  • Great answer! $,$ – Fernando Martin Jul 08 '12 at 03:44
  • I find it disturbing that the same notation is used for the dual, which can exist absent an inner product, and the adjoint, which requires an inner product. I know this is customary, but is there any notation you're aware of that distinguishes them? – ItsNotObvious Jul 08 '12 at 03:46
    I've seen the adjoint notated with a dagger sometimes (e.g. $A^\dagger$). – Fernando Martin Jul 08 '12 at 03:48
  • @Aaron: Could you explain why is $A^$ defined that way? (I mean, why is it defined such that $A^(v)=\phi^{-1}(A^*\phi(v))$). It's not so clear to me why that map satisfies the definition of adjoint. Thanks a lot! – Fernando Martin Jul 08 '12 at 04:16
  • @ItsNotObvious: I like the notation $A^{\dagger}$. See http://en.wikipedia.org/wiki/Dagger_category . – Qiaochu Yuan Jul 08 '12 at 05:44
  • @Aaron: What I get is that $\langle Ax,y\rangle=\phi(Ax)(y)=A^\phi(x)(y)=\phi(\phi^{-1}A^\phi(x))(y) = \langle A^\dagger x,y\rangle$, which isn't what I actually want. Is there an error in that derivation? (I'm using $A^*$ for the transpose and $A^\dagger$ for the adjoint). – Fernando Martin Jul 08 '12 at 06:01
  • @FernandoMartin: The problem is that $\phi(Ax)\neq A^\phi(x)$. The issue is that $\phi$ is not an element of $V^$, but rather a map $V\to V^*$. We only do the moving around when we view elements of the dual space as functions, we don't move them with arbitrary linear maps. – Aaron Jul 08 '12 at 15:41
  • @Aaron: Ahhh, absolutely. Thanks! – Fernando Martin Jul 08 '12 at 17:21
  • @FernandoMartin: You're welcome. I hope the last few lines cleared up your confusion. It's also worth pointing out that, in the finite dimensional case, if you take a basis, $(e_i)$, you have a corresponding dual basis $(f_j)$ defined by $f_j(e_i)=\delta_{ij}$. Moreover, we can take the dot product as the inner product, $\langle e_i, e_j \rangle=\delta_{ij}$, and so under the isomorphism in the post, $\phi(e_i)=f_i$. With this, you can calculate that $A^{\dagger}=A^{T}$, the transpose. – Aaron Jul 09 '12 at 14:08
You should think of $A^{\ast}$ as the "backwards" version of $A$ (not to be confused with its inverse).
Let's work in a related setting, namely that of sets and relations. Recall that a relation $R$ from a set $X$ to a set $Y$ is a subset of $X \times Y$. I want to think of a relation as a kind of function from $X$ to $Y$, but which outputs subsets rather than elements of $Y$; we say that $Rx$ is the set of all $y$ such that $(x, y)$ lies in my subset.
More generally, if $E$ is a subset of $X$, then $RE$ is the set of all $y$ such that $(x, y)$ lies in my subset for some $x \in E$.
Sets admit an "inner product" taking values in $\{ 0, 1 \}$ defined as follows: if $S, T$ are two subsets of a set $X$, then we define $\langle S, T \rangle = 1$ if $S \cap T$ is non-empty and $\langle S, T \rangle = 0$ otherwise.
Now, I claim that for any relation $R : X \to Y$ there is a unique relation $R^{\ast} : Y \to X$ such that $$\langle RE, F \rangle = \langle E, R^{\ast} F \rangle$$
for all subsets $E$ of $X$ and $F$ of $Y$. It turns out that $R^{\ast}$ is just the subset $\{ (y, x) : (x, y) \in R \}$; thinking of a relation as a matrix with entries in $\{ 0, 1 \}$ it is the transpose matrix.
Thinking of a relation as a collection of arrows from elements of $X$ to elements of $Y$, taking adjoints of relations corresponds to reversing the direction of all of the arrows. This is roughly speaking what happens when you take the adjoint of a bounded linear operator between Hilbert spaces.
Qiaochu Yuan
  • 419,620
