There are more sophisticated ways to solve the problem, for instance by using generating functions as suggested by Masacroso in the comments, but you can also use quite elementary tools: the stars and bars approach combined with the inclusion-exclusion principle.
If we ignore the upper bound of $6$, the former says that there are
$$\binom{26-1}{6-1}=\binom{25}5\tag{1}$$
solutions. Some of them, however, violate one or more of the upper bounds. Let’s see how many of them have $q_1\ge 7$.
Let $x_1=q_1-6$; then the solutions with $q_1\ge 7$ are exactly the positive solutions to
$$x_1+q_2+q_3+q_4+q_5+q_6=26-6=20\;,$$
and by the stars and bars calculation there are $\binom{20-1}{6-1}=\binom{19}5$ of them. There are also $\binom{19}5$ solutions with $q_2\ge 7$, $\binom{19}5$ with $q_3\ge 7$, and so on, so $(1)$ should be corrected to
$$\binom{25}5-6\cdot\binom{19}5\;.\tag{2}$$
Unfortunately, this overcorrects: any solution that has two of the variables greater than $6$ is counted once in $(1)$ but then subtracted twice in $(2)$ and is therefore counted $-1$ times instead of the desired $0$ times. Thus, we need to correct $(2)$ by adding back in the solutions that have two variables larger than $6$.
How many solutions are there with $q_1,q_2\ge 7$? Use the same trick as before. Let $x_1=q_1-6$ and $x_2=q_2-6$, and count the positive solutions to
$$x_1+x_2+q_3+q_4+q_5+q_6=26-2\cdot 6=14\;;$$
there are $\binom{14-1}{6-1}=\binom{13}5$ of them that we need to add back in to $(2)$. We need to do that for each of the $\binom62$ pairs of variables, so we correct $(2)$ to
$$\binom{25}5-6\cdot\binom{19}5+\binom62\binom{13}5\;.\tag{3}$$
And once again we’ve overcorrected: any solution to the original equation that has three variables over $6$ has been counted once in $(1)$, subtracted $3$ times in $(2)$, and added back in $3$ times in $(3)$, for a net count of $1$ instead of the desired $0$, so it has to be subtracted. I’ll not go through the details this time, because the reasoning is the same; we end up with $\binom63$ possible sets of $3$ variables, and for each of those sets $\binom{7}5$ solutions with all $3$ exceeding $6$, resulting in an improved result of
$$\binom{25}5-6\cdot\binom{19}5+\binom62\binom{13}5-\binom63\binom75\;.\tag{4}$$
And it’s not possible for a solution to have $4$ of the variables exceeding $6$, so we’re done: $(4)$ is the final total, and it works out to $2247$.
