Let $s$ be any complex number, $t = e^s$ and $z = t^{1/t}$. Define the sequence $(a_n)_{n\in\mathbb{N}}$ by $a_0 = z $ and $a_{n+1} = z^{a_n} $ for $n \geq 0$, that is to say $a_n$ is the sequence $z$, $z^z$, $z^{z^z}$, $z^{z^{z^{z}}}$ and so on.
I want to show that the sequence $(a_n)_{n\in\mathbb{N}}$ converges to $t$ if and only if $s$ lies in the unit disk. I know that when the sequence converges the limit is $\frac{W(-\ln(z))}{-\ln(z)}$ where $W$ is the Lambert W function.
I have verified the above statements numerically for several thousand values of $z$ but I have no idea how to actually prove it.
I graphed the natural logs of the limits on my computer. I got what appeared to be the unit disk.
If we take the log of the limit we get $\ln\left(\frac{W(−\ln(z)}{−\ln(z)}\right)=-\ln(−\ln(z))−W(−\ln(z))+\ln(−\ln(z))=−W(−\ln(z))$
So what I want to prove is equivalent to showing the sequence $a_n$ is convergent if and only if $|W(−\ln(z))| \leq 1$
I was reading the Wikipedia article on the Lambert W Function and I found this proof that the limit $c$, when it exists, is $c= \frac{W(-\ln(z))}{-\ln(z)}$
$z^c = c\implies z = c^{1/c} \implies z^{-1} = c^{-1/c} \implies 1/z = (1/c)^{1/c} \implies -\ln(z) = \frac{\ln(1/c)}{c} \implies -\ln(z) = e^{\ln(1/c)}\ln(1/c) \implies \ln(1/c) = W(-\ln(z)) \implies 1/c = e^{W(-\ln(z))} \implies \frac{1}{c} = \frac{-\ln(z)}{W(-\ln(z)} \implies c = \frac{W(-\ln(z)}{-\ln(z)}$
I can only assume that at least 1 step is not justified when $|W(-\ln(z)| > 1$ though I am not sure which one. I think that part of the problem is the equation $z^c=c$ has a solution for every non-zero complex number $c$ while the sequence $a_n$ only converges for certain special values of z. In other words the convergence of the $a_n$ is a sufficient but not necessary condition for the existence of a solution to the equation.
cpiegore
  • 1,490
  • @Did Here $w$ is the Lambert W function; it is not an undefined variable. – cpiegore Feb 13 '16 at 04:45
    What is $u^z$ when $u$ and $z$ are complex numbers? – Did Feb 13 '16 at 04:46
  • @Did In polar coordinates $(re^{iu})^(se^{iv}) = (re^{iu})^s*(re^{iu}))^(e^{iv}) = ?$ – cpiegore Feb 13 '16 at 04:56
  • @Did In polar coordinates $(re^{iu})^(se^{iv}) = (re^{iu})^s*(re^{iu}))^(e^{iv}) = r^{s}e^{ius}r^{e^{iu}}e^{-uv} = r^{s+iu}e^{ius-uv}=?$ – cpiegore Feb 13 '16 at 05:07
  • Why does everyone seem to answer questions in the comments? – cpiegore Feb 13 '16 at 05:13
    Except that, unless $z$ is an integer, this leads to possibly infinitely many values for $u^z$... For example, $u=1$ and $z=\sqrt2$ would yield that $u^z$ is $\exp(2i\pi n\sqrt2)$ for every integer $n$, which is a dense set of points on the unit circle. This example indicates the question is in serious need of explanations. – Did Feb 13 '16 at 06:48
  • I suppose I should point that I am defining all of the expressions using the principal branch of the natural log – cpiegore Feb 13 '16 at 07:07
  • This is another problem for another day, but I am attempting to extend my results so that they are valid for any branch of the natural log. My progress on this has been very slow. – cpiegore Feb 13 '16 at 07:10
  • @Did You are correct in that the expression $u^z$ is multivalued, since the complex logarithm is multivalued. Please note however that I am restricting my attention to the principal branch of the log so that all expressions are single-valued. Note also that in the original post, only $s$ is arbitrary; $t$, $z$ and the sequence $a_n$ are all defined in terms of $s$. – cpiegore Feb 13 '16 at 20:24
    Maybe start with complex number $a$ (to be thought of as $\log z$), then iterate using function $t \mapsto \exp(at)$ instead of function $x \mapsto z^x$. – GEdgar Feb 15 '16 at 16:23
  • I'm starting to wonder if my question is even answerable – cpiegore Feb 15 '16 at 18:19
  • I tried, unsuccessfully, sorry. – Næreen Feb 15 '16 at 21:01
  • @Næreen What was your idea? – cpiegore Feb 15 '16 at 21:47
  • If anybody has any idea at all please say it. I am wide open to suggestions. – cpiegore Feb 16 '16 at 02:59
$$a_0 = z\qquad \qquad \qquad a_{n+1} = z^{a_n}$$
let $b_n = \ln a_n$ so $a_n = e^{b_n}$ and $$b_{n+1} = \ln \left(z^{e^{b_n}}\right) = e^{b_n} \ln z$$
if $b_n$ converges to $b$ then $b = e^b \ln z = - e^{b} (-\ln z)$ so
$$b = e^b \ln z = W(-\ln z)$$
where $W$ is (one of the branches of ?) the Lambert function.
let $c_n = b_n - b$ so $$c_{n+1} = e^{(b + c_n)} \ln z - b= (e^b \ln z) e^{c_n} - b = b e^{c_n} - b = b (e^{c_n} - 1)$$
suppose $|b| > 1$ and $\ln z \ne 0$. then suppose $b_n \to b$ thus $c_n \to 0$ so $e^{c_n}-1 \sim c_n$ so $c_{n+1} \sim b c_n $ which clearly cannot converge except if $c_0 = 0$ which would imply $c_n = 0$ for every $n$ which is not the case because $b_0 = \ln z$ so $b_1 = e^{\ln z} \ln z \ne b_0$ so $c_1 \ne c_0$ $\implies$ a contradiction.
hence if $\ln z \ne 0$ $$|b| = \left|W(-\ln z)\right| \le 1$$ is a necessary condition for the convergence of $(b_n)$ and $(a_n)$
reuns
  • 77,999
  • Can you show that $|b| \leq 1$ is also a sufficient condition for the convergence of the sequences? – cpiegore Feb 18 '16 at 23:07
  • Also, a few some minor points: first $b = ln(a)$ is actually equal to $-W(-ln(z))$. Second I believe it is not necessary to assume $ln(z) \ne 0$ or $z \ne 1$; $W(0)$ is perfectly well defined since $0*e^0 =0$ and $0 \leq 1$. Looks good otherwise. – cpiegore Feb 18 '16 at 23:11
  • Can you show that $|b| \leq 1$ is also a sufficient condition for the convergence of the sequences? – cpiegore Feb 20 '16 at 14:35
    @cpiegore : as I shown it reduces to solving the convergence of $c_{n+1} = b(e^{c_n}-1)$ which is easy in $\mathbb{R}$ but much less in $\mathbb{C}$. it is probably already solved somewhere so make a research. and you'll probably have to show by induction that $Re(c_n)$ and $|c_n|$ let $c_n$ converge, maybe by studying $arg(c_n)$ ? you could also simulate the sequence on a computer to see what is happening when it converges or diverges (and I don't think it converges for most $|b| = 1$). – reuns Feb 20 '16 at 22:58
I was reading the Wikipedia article on the Lambert W Function and I found this proof that the limit $c$, when it exists, is $c= \frac{w(-ln(z))}{-ln(z)}$
$z^c = c\implies z = c^{1/c} \implies z^{-1} = c^{-1/c} \implies 1/z = (1/c)^{1/c} \implies -ln(z) = \frac{ln(1/c)}{c} \implies -ln(z) = e^{ln(1/c)}ln(1/c) \implies ln(1/c) = W(-ln(z)) \implies 1/c = e^{W(-ln(z))} \implies \frac{1}{c} = \frac{-ln(z)}{W(-ln(z)} \implies c = \frac{W(-ln(z)}{-ln(z)}$
I can only assume that at least 1 step is not justified when $|W(-ln(z)| > 1$ though I am not sure which one.
cpiegore
  • 1,490
