This post might appear as a duplicate of the following:
Over an integral arising from Kepler's problem [also: generally useful integral]
So recalling quickly:
$$\Phi(\epsilon) = \frac{1}{2\pi}\int_0^{2\pi}\ \frac{\sin^2\theta\ \text{d}\theta}{(1 + \epsilon\cos\theta)^2}$$
Note: The integral arises in studying the Kepler's problem, which is why $\epsilon\in [0;\ 1]$.
Necessary Note I tried to solve it with complex analysis, as you can see in the above link, but in my book it's solved by series with lots of unknown passages, which I will write down here.
$$ \begin{align*} \frac{1}{2\pi}\int_0^{2\pi}\ \frac{\sin^2\theta\ \text{d}\theta}{(1 + \epsilon\cos\theta)^2} & = \sum_{n = 1}^{+\infty}\ (-1)^n\epsilon^n(n+1)\cdot\frac{1}{2\pi}\int_0^{2\pi}\ (1 - \cos\theta)\cos^n\theta\ \text{d}\theta \\\\ & = \sum_{n = 0}^{+\infty}\ \epsilon^{2n}(2n+1)\left[\frac{1}{2^{2n}} \binom{2n}{n} - \frac{1}{2^{2n+2}}\binom{2n+2}{n+1}\right] \\\\ & = \sum_{n = 0}^{+\infty}\ \epsilon^{2n}\frac{2n+1}{2^{2n+2}} \frac{(2n)!}{(n!)^2} \left[4 - \frac{(2n+1)(2n+2)}{(n+1)^2}\right] \\\\ & = \sum_{n = 0}^{+\infty}\ \epsilon^{2n} \frac{(2n+1)!}{2^{2n+1}(n!)^2 (n+1)} \\\\ & = \frac{1}{\epsilon^2}\ \sum_{n = 0}^{+\infty} \epsilon^{2(n+1)}(-1)^{n+1}\binom{-1/2}{n+1} \\\\ & = \frac{1}{\epsilon^2}[(1 - \epsilon^2)^{-1/2} - 1] \end{align*} $$
Can anybody help with that? It seems really messy..
P.s. I wrote down here exactly the passages of the book.
What I need
I am not familiar with the passage from the first row to the second one (namely: where the integral has been solved, in which we pass to the binomial coefficient). In addition to that, I didn't understand how the very last series has been summed.
