This is just a curiosity that just came to my mind while thinking at IP addresses. A byte is composed of 8 bits. A bit can either be $0$ or $1$. IPv4 addresses are composed of a group of 4 bytes. These bytes are usually represented in decimal dot notation (because it's easier for humans), but sometimes I need to figure out in my head the binary numbers. So, if I know that there's just one configuration, and if my calculations are correct, then I am sure that my solution is correct.
My question is, is possible to obtain a certain integer $k$ using more than one combination of the $8$ bits? For example, suppose we want to represent in binary the number $123$. Is it possible to represent it in 2 or more different configurations of the 8 bits? What about if we have more than $8$ bits?
This might seem a silly question, but a proof might satisfy me.
