I'm trying to work out sum of this series $$1 + \frac{2}{2} + \frac{3}{2^2} + \frac{4}{2^3} + \ldots$$
I know one method is to do substitutions and getting the series into a form of a known series. So far I've converted the series into $$ 1 + \frac{2}{x} + \frac{3}{x^2} + \frac{4}{x^3} + \ldots $$ where $x=2$ and I'm trying to get it into the form of the $\ln(1+x)$ series somehow. I have tried differentiating, integrating and nothing is working out. The closest I got is by inverting which gave me $ 1 + \frac{x}{2} + \frac{x^2}{3} + \frac{x^3}{4} \ldots $
Now I'm just lost and have no idea what to do.
The other idea I had was converting it into $$ \Large{\sum_{n=1}^\infty{\frac{n}{2^{n-1}}}}, $$ but I have no idea how to do anything further to it. How would you do this? Thnx.
csbk
  • 33
Csbk
  • You could try integrating? If it were in the form $x+2x^2+3x^3+4x^4\cdots$, we could integrate, find the solution, then take the derivative of that. – Simply Beautiful Art Jan 05 '16 at 00:58
Cherry pick the terms into series you can sum. THus you know how to do $$ 1 + \frac{1}{2} + \frac{1}4 + \frac{1}{8}+ \frac{1}{16} \cdots = 2$$ and you are left with $$ \frac{1}{2} + \frac{2}4 + \frac{3}{8} + \frac{3}{16} \cdots $$ so cherry pick again: $$ \frac{1}{2} + \frac{1}4 + \frac{1}{8}+ \frac{1}{16} \cdots = 1$$ leaving $$ \frac{1}4 + \frac{2}{8} + \frac{3}{16} \cdots $$ And next you will get $\frac{1}{2}$ and so forth. Then sum all of those sums, to get the answer, which is somewhere around $4$.
Mark Fischler
  • 41,743
You started with this, which I will set equal to $k$:
$$1 + \frac{2}{2} + \frac{3}{2^2} + \frac{4}{2^3} + \ldots=k$$
Use the substitution $x=\frac12$.
$$1+2x+3x^2+4x^3+\ldots=k$$
This is where it gets a little bit confusing. We have to integrate the left side, find a solution to it, then differentiate the solution.
$$\int 1+2x+3x^2+4x^3+\ldots dx=x+x^2+x^3+x^4\ldots=\sum_{n=1}^{\infty}x^n$$
We have a well known solution for this:
$$\sum_{n=1}^{\infty}x^n=\frac1{1-x}$$
Now return to what we wanted in the first place:$$\int1+2x+3x^2+4x^3\ldots dx=\frac1{1-x}$$
Differentiate both sides to get:
$$1+2x+3x^2+4x^3\ldots=\frac1{(1-x)^2}$$
Use $x=\frac12$.
$$1 + \frac{2}{2} + \frac{3}{2^2} + \frac{4}{2^3} + \ldots=\frac1{(1-\frac12)^2}=4=k$$
Note that this is probably going to arouse some conversation, so I will try my best to explain why I can do this.
If I differentiate and integrate two functions $f(x)$ and $g(x)$ that are equal to each other, then we will have $f'(x)=g'(x)$ if and only if $f(x)+C=g(x)$ for all $x$.
$$f(x)+C=g(x)$$
$$f'(x)=g'(x)$$
You can support this with a bit of graphing.
You may also note that I ignored the constant of integration when I integrated, only because I would differentiate in the near future, which would negate my constant of integration.
This method may produce what you might consider the correct answer, and numerical checks say I am correct.
