Let $\Delta$ be a sort of difference operator on a function $f(n)$ such that $$\Delta f(n)=f(n+1)-f(n)$$ Take the basic power function $f(n)=n^k$, $k\in\mathbb{N}\cup\{0\}$. Then we get $$\begin{cases}\Delta 1=0\\[1ex] \Delta n=1\\[1ex] \Delta n^2=2n+1\\[1ex] \Delta n^3=3n^2+3n+1 \end{cases}$$ and so on, with the general form $$\Delta n^k=(n+1)^k-n^k=\sum_{i=0}^{k-1}\binom kin^k$$ I'm wondering if there's a parallel closed form for $n^k$ in terms of $\Delta n^{k+1},\Delta n^k,\ldots,\Delta n$? What I mean by this is that for $n$, we can write $$n=\frac{\Delta n^2}{2}-\frac{\Delta n}{2}$$ since $$\frac{\Delta n^2}{2}-\frac{\Delta n}{2}=\frac{2n+1}{2}-\frac{1}{2}=n$$ Similarly, one can show that $$\begin{cases}n^2=\dfrac{\Delta n^3}{3}-\dfrac{\Delta n^2}{2}+\dfrac{\Delta n}{6}\\[1ex] n^3=\dfrac{\Delta n^4}{4}-\dfrac{\Delta n^3}{2}+\dfrac{\Delta n^2}{4}\\[1ex] n^4=\dfrac{\Delta n^5}{5}-\dfrac{\Delta n^4}{2}+\dfrac{\Delta n^3}{3}-\dfrac{\Delta n}{30}\end{cases}$$ and so on, with no immediate pattern as far as I can tell. Is there one?
user170231
  • 19,334
    It boils down to showing that the linear system (a matrix similar to $a_{ij}={i \choose j}$ for $i \leq j$ and zero otherwise) you have has a nonzero determinant. – abnry Dec 28 '15 at 18:43
    @nayrb: I've added an answer with a different approach which might be interesting. Regards, – Markus Scheuer Mar 24 '16 at 20:52
  • Are you sure, that in the last (=$n^4$) equation the linear term $- \frac {\Delta n}{30}$ is negative and not positive? – Gottfried Helms Mar 25 '16 at 07:20
We derive a formula for $n^k$ in terms of $\Delta n^k$ by use of binomial inverse pairs and their generating functions. We show
the following is valid \begin{align*} n^k=\frac{1}{k+1}\sum_{i=0}^{k+1}\binom{k+1}{i}\Delta n^iB_{k+1-i}\qquad\qquad k\geq 0 \end{align*} with $B_k$ the Bernoulli numbers.
We define \begin{align*} A(x)=\sum_{k=0}^\infty\Delta n^k\frac{x^k}{k!}\qquad\qquad B(x)=\sum_{k=0}^{\infty}n^k\frac{x^k}{k!} \end{align*}
According to the definition of the $\Delta$ operator we obtain \begin{align*} A(x)&=\sum_{k=0}^{\infty}\Delta n^k\frac{x^k}{k!}\\ &=\sum_{k=0}^{\infty}\left((n+1)^k-n^k\right)\frac{x^k}{k!}\\ &=\sum_{k=0}^{\infty}\sum_{i=0}^{k-1}\binom{k}{i}n^i\frac{x^k}{k!}\\ &=\sum_{k=0}^{\infty}\sum_{i=0}^{k}\binom{k}{i}n^i\frac{x^k}{k!}-\sum_{k=0}^{\infty}n^k\frac{x^k}{k!}\\ &=\left(\sum_{k=0}^{\infty}n^k\frac{x^k}{k!}\right)\left(e^x-1\right)\tag{1}\\ &=B(x)\left(e^x-1\right)\tag{2} \end{align*}
Comment:
  • In (1) we use the multiplication of exponential generating functions \begin{align*} \left(\sum_{k=0}^\infty a_k \frac{x^k}{k!}\right)\left(\sum_{k=0}^\infty b_k \frac{x^k}{k!}\right) =\sum_{k=0}^\infty\left(\sum_{i=0}^k\binom{k}{i}a_i b_{k-i}\right)\frac{x^k}{k!} \end{align*} with $a_k=n^k$ and $b_k=1$ for all $k\geq 0$.
  • In (2) we see the relationship between $\Delta n^k$ und $n^k$ in terms of generating functions.
From (2) we obtain the generating function $B(x)$ for $n^k$ by the generating function $A(x)$ as \begin{align*} B(x)&=A(x)\frac{1}{e^x-1}\\ &=\frac{1}{x}A(x)\frac{x}{e^x-1}\tag{3} \end{align*}
In (3) we see the generating function of the Bernoulli numbers \begin{align*} \frac{x}{e^x-1}=\sum_{k=0}^\infty B_k\frac{x^k}{k!} \end{align*}
and we obtain \begin{align*} B(x)&=\frac{1}{x}A(x)\frac{x}{e^x-1}\\ &=\frac{1}{x}\left(\sum_{k=0}^{\infty}\Delta n^k\frac{x^k}{k!}\right)\left(\sum_{k=0}^\infty B_k\frac{x^k}{k!}\right)\\ &=\frac{1}{x}\sum_{k=0}^{\infty}\left(\sum_{i=0}^k\binom{k}{i}\Delta n^i B_{k-i}\right)\frac{x^k}{k!}\tag{4} \end{align*}
Comparing coefficients of $B(x)$ and the RHS of (4) gives
\begin{align*} \frac{1}{k!}n^k&=\sum_{i=0}^{k+1}\binom{k+1}{i}\Delta n^iB_{k+1-i}\frac{1}{(k+1)!}\qquad\qquad k\geq 0\\ n^k&=\frac{1}{k+1}\sum_{i=0}^{k+1}\binom{k+1}{i}\Delta n^iB_{k+1-i} \end{align*} and the claim follows.
Epilogue Binomial inverse pairs
Let's summarise the result about this binomial inverse pair. We observe the following relationship \begin{align*} A(x)&=\sum_{k=0}^\infty\Delta n^k\frac{x^k}{k!}&B(x)&=\sum_{k=0}^{\infty}n^k\frac{x^k}{k!}\\ &=B(x)\left(e^x-1\right)&&=\frac{1}{x}A(x)\frac{x}{e^x-1}\\ \Delta n^k&=\sum_{i=0}^{k-1}\binom{k}{i}n^k&n^k&=\frac{1}{k+1}\sum_{i=0}^{k+1}\binom{k+1}{i}\Delta n^iB_{k+1-i} \end{align*}
Markus Scheuer
  • 108,315
