Possible Duplicate:
Proof of the formula $1+x+x^2+x^3+ \cdots +x^n =\frac{x^{n+1}-1}{x-1}$
Value of $\sum\limits_n x^n$
I'm working on some math programming and ran into the following recursive series.
$\displaystyle\sum\limits_{i=1}^n a_n$. Where $a_{n} = Ca_{n-1}$ and $0 \leq C \leq 1$ and $a_0$ is given;
Because my constant values are always between 0 and 1, I know that the series converges and I can't help but thinking that there must be a solution.
My code looks something like
value = 1000000;
constant = 0.9999;
total = 0;
tolerance = 0.001;
while(value > tolerance)
    value = constant * value;
    total = total + value;
Problem is, as is the case with the initial values provided in the snippet above, the algorithm takes a long time to complete when $C$ approaches $1$
  • $a_1 = C a_0$, $a_2 = Ca_1 = C^2 a_0$, $a_3 = Ca_2 = C^3 a_0$ and in general $a_n = C^n a_0$. Hence, $$\sum_{k=0}^{n} a_k = \sum_{k=0}^{n} \left(a_0C^k \right) = \underbrace{a_0 \left( \sum_{k=0}^{n} C^k\right) = a_0 \left(\dfrac{C^{n+1}-1}{C-1} \right)}{\text{Sum of a geometric progression when $C \neq 1$}}$$ If $C=1$, you get $\displaystyle \sum{k=0}^{n} a_k = \displaystyle \sum_{k=0}^{n} a_0 = (n+1)a_0$.
    You can find on how to evaluate a geometric progression in the link below.
    (http://math.stackexchange.com/questions/29023/)
    –  Jun 16 '12 at 19:29
  • Note that in your code you stop adding terms as soon as one term is smaller than tolerance. The total of all the terms after that to infinity is $\frac {tolerance}{1-C}$. If $C$ is close to $1$ this can be large. In your case, it would be 100. – Ross Millikan Jun 16 '12 at 19:40
$a_k$ can be written as:
$$a_k = a_0 \cdot \underbrace{C \cdot C \cdots C}_{k \text{ times}} = a_0 C^{k}$$
Where $a_0 = 1000000$ and $C = 0.9999$. ($0 \lt C \lt 1$)
The sum is a geometric series. It has the following closed form:
$$ \sum_{k=0}^n a_k = a_0 \frac{1-C^{n+1}}{1-C} $$
And as $n \to \infty$:
$$ \sum_{n=0}^\infty a_n = \frac{C_0}{1-C} $$
On the other hand, if $C=1$, then $a_k=a_0$ and the sum becomes:
$$ \sum_{k=0}^n a_k = (n+1)a_k $$
And this diverges as $n \to \infty$.
Ayman Hourieh
  • 39,603
