I am stuck at this example from Wikipedia on differentiation under the integral sign.
$$\int_0^\pi\frac {1-\alpha^2}{1-2\alpha\cos x + \alpha^2} dx$$
Any help?
Edits:
  1. The last term in the denominator is changed to $\alpha^2$.
  2. This integral appears in example 3 of the Wikipedia article https://en.wikipedia.org/wiki/Differentiation_under_the_integral_sign.
Asaf Karagila
  • 393,674
Rodrigo
  • 7,646
    Are you sure it is the right integral? It would make much more sense if the denominator was $1-2\alpha\cos(x)\color{red}{+\alpha^2}$. – Jack D'Aurizio Dec 27 '15 at 01:17
  • Please unblock it. Jack D'Aurizio's comment corrects the typo. This integral appears in the Wikipedia article https://en.wikipedia.org/wiki/Differentiation_under_the_integral_sign in its example 3. With the typo corrected, the integral can be solved. – Amey Joshi Dec 27 '15 at 03:18
5 Answers5
Let us write the integrand as \begin{equation} g(x) = \frac{1 - \alpha^2}{1 - 2\alpha\cos x + \alpha^2} \end{equation} We first write $\cos x = \cos^2(x/2) - \sin^2(x/2)$, $1 = \cos^2(x/2) + \sin^2(x/2)$ and $\alpha^2 = \alpha^2(\cos^2(x/2) + \sin^2(x/2))$ to get \begin{equation} g(x) = \frac{(1 - \alpha^2)\sec^2(x/2)}{(1 - \alpha)^2 + (1 + \alpha)^2\tan^2(x/2)} \end{equation} which is same as \begin{equation} g(x) = 2\frac{1 + \alpha}{2}\frac{(1 - \alpha)\sec^2(x/2)}{(1 - \alpha)^2 + (1 + \alpha)^2\tan^2(x/2)} \end{equation} or, \begin{equation} g(x) = 2\frac{1}{1 + \frac{(1 + \alpha)^2}{(1 - \alpha)^2}\tan^2(x/2)}\frac{1 + \alpha}{1 - \alpha}\sec^2(x/2)\frac{1}{2} \end{equation} or \begin{equation} g(x) = 2 \frac{1}{1 + \left(\frac{1 + \alpha}{1 - \alpha}\right)^2\tan^2\left(\frac{x}{2}\right)}\frac{d}{dx}\left[\frac{1 + \alpha}{1 - \alpha}\tan\left(\frac{x}{2}\right)\right] \end{equation} Therefore, \begin{equation} \int g(x)dx = 2\tan^{-1}\left(\frac{1 + \alpha}{1 - \alpha}\tan\left(\frac{x}{2}\right)\right) + c, \end{equation} where $c$ is a constant of integration. Therefore, \begin{equation} \int_0^\pi \frac{1 - \alpha^2}{1 - 2\alpha\cos x + \alpha^2} dx = \begin{cases} \pi & |\alpha| < 1 \\ -\pi & |\alpha| > 1 \end{cases} \end{equation}
Amey Joshi
  • 1,084
This is a typical example which can be solved by the residue theorem:
We have that (with $z=e^{ix}$)
\begin{align*} I&= \int_0^\pi\frac {1-\alpha^2}{1-2\alpha\cos x + \alpha^2} dx \\ &=\frac12 \int_{-\pi}^\pi\frac {1-\alpha^2}{1-2\alpha\cos x + \alpha^2} dx \\ &= \frac1{2i} \oint_{|z|=1} \!\frac{dz}z\, \frac{1-\alpha^2}{1 + \alpha^2 -\alpha (z+z^{-1})} \end{align*}
The denominator is given by $$ d= z (1+\alpha^2) -\alpha (1+ z^2)$$ and has the poles $z_1=\alpha$ and $z_2=1/\alpha$.
(1) For $|\alpha|<1$ the pole at $z=z_1$ contributes, and we obtain $$I = \pi \mathop{\rm Res}_{z=\alpha} \frac{1-\alpha^2}{d} = \pi.$$
(2) For $|\alpha|>1$ the pole at $z=z_2$ contributes, and we obtain $$I = \pi \mathop{\rm Res}_{z=1/\alpha} \frac{1-\alpha^2}{d} = -\pi.$$
Aritra Das
  • 3,528
Fabian
  • 23,360
If $|\alpha| < 1$ then we know that $$1 + 2\alpha\cos x + 2\alpha^{2}\cos 2x + \cdots = \frac{1 - \alpha^{2}}{1 - 2\alpha\cos x + \alpha^{2}}\tag{1}$$ Now integrating the above identity with respect to $x$ on interval $[0, \pi]$ we get the desired integral as $\pi$ (because $\int_{0}^{\pi}\cos nx \,dx = 0$). If $|\alpha| > 1$ then we note that $$\frac{1 - \alpha^{2}}{1 - 2\alpha\cos x + \alpha^{2}} = - \dfrac{1 - \dfrac{1}{\alpha^{2}}}{1 - \dfrac{2}{\alpha}\cos x + \dfrac{1}{\alpha^{2}}}$$ and since $|1/\alpha| < 1$ we see that the desired integral is equal to $-\pi$.
i guess, to the case $\vert{\alpha}\vert=1$, your result is different (maybe zero). because, under this assumption, only when $cosx=\frac{a^2+1}{2a}$, your integration will not be zero. so we can compute as below :
$\int_{0}^{\pi}\frac{1-\alpha^2}{1-2\alpha{cosx}+\alpha^2}dx=$$\int_{0}^{\pi}\frac{2(1-\alpha{cosx})}{1-2\alpha{cosx}+\alpha^2}dx$
pick $y=\alpha{cosx}$ and you can see it :
$\int_{0}^{\pi}\frac{2(1-\alpha{cosx})}{1-2\alpha{cosx}+\alpha^2}dx=$$\int_{0}^{\pi}\frac{2(1-y)}{1-2y+\alpha^2}dx=$$\int_{-1}^{1}\frac{1}{\sqrt{1-y^2}}dy=$$\alpha{\theta\vert_{-\pi/2}^{\pi/2}}=\vert{\pi}\vert$
but if you multiple $\vert{\pi}\vert$ with $\epsilon$, the result will be zero too!
ALIX
On page 393, Entry 3.613, in the monograph
I. S. Gradshteyn and I. M. Ryzhik, Table of Integrals, Series, and Products, Translated from the Russian, Translation edited and with a preface by Daniel Zwillinger and Victor Moll, Eighth edition, Revised from the seventh edition, Elsevier/Academic Press, Amsterdam, 2015; available online at https://doi.org/10.1016/B978-0-12-384933-5.00013-8,
the formula \begin{equation*} \int_0^\pi\frac{\cos(nx)\operatorname{d}x}{1-2a\cos x+a^2}= \begin{cases} \dfrac{\pi a^n}{1-a^2}, & a^2<1\\ \dfrac{\pi}{(a^2-1)a^n}, & a^2>1 \end{cases} \end{equation*} for $n\ge0$ is listed. Consequently, taking $n=0$ gives the result \begin{gather*} \int_0^\pi\frac{(1-a^2)\operatorname{d}x}{1-2a\cos x+a^2}= (1-a^2)\int_0^\pi\frac{\operatorname{d}x}{1-2a\cos x+a^2}\\ =(1-a^2) \begin{cases} \dfrac{\pi}{1-a^2}, & a^2<1\\ \dfrac{\pi}{(a^2-1)}, & a^2>1 \end{cases} =\begin{cases} \pi, & a^2<1\\ -\pi, & a^2>1 \end{cases} \end{gather*} for $a^2\ne1$.
qifeng618
  • 1,691
