The problem $xe^{e^x}=e$ came up another day and I wondered if it were solvable.
My attempt was the following substitution,$$x=W(u)$$$$W(u)e^{e^{W(u)}}=e$$Where I used a Lambert W identity to get $$W(u)e^{\frac u{W(u)}}=e$$And attempted to solve.
I got this far:$$-\frac1{W(u)}e^{-\frac u{W(u)}}=-\frac1e$$However, I couldn't continue. Its so darn close... but alas, its not quite there.
So I've come to you guys for help, well knowing that most of you will say "no solution" of closed form, but that's ok. I will even accept answers that attempt to continue or start from the beginning to try out a different path for the solution.
I also considered the following: If you could get into a form where adding/subtracting/multiplying/dividing/whatever will cancel a part of the equation with a previous form, then that'll be great e.g.$$f(u)W(u)=g(u)$$$$xf(u)=W(u)$$Divide the two and you get $$\frac{W(u)}x=\frac{g(u)}{W(u)}$$$$W^2(u)=xg(u)$$Noting that you can switch around with substitutions as long as you are consistent with your substitutions.
I also realize that in the beginning, I could have used the substitution $x=-W(x)$ to flip the resulting fraction to put the $W$ on top and repeat the Lambert identity process, only to create$$-W(u)[\frac{u}{W(u)}]^{1/u}=e$$ Which is still not solvable!
