This isn't true if $I$ is infinite. It is easy to see that $|E(I)|=2^{|I|}$; I claim that $|A(I)|=2^{2^{|I|}}$.
To show this, let $\beta I$ be the Stone space of $P(I)$, i.e. the space of ultrafilters on $I$. Note that $\beta I$ is the free compact Hausdorff space on the set $I$ (with elements of $I$ corresponding to the principal ultrafilters). So any map $I\to \beta I$ extends uniquely to a continuous map $\beta I\to \beta I$. It follows that any map $I\to \beta I$ with dense image extends to a continuous surjection $\beta I\to \beta I$, which is then dual to an injective homomorphism $P(I)\to P(I)$. Since the principal ultrafilters are dense in $\beta I$, we can construct maps $I\to \beta I$ with dense image by splitting $I$ into two subsets of cardinality $|I|$, mapping one of them onto all the principal ultrafilters, and then mapping the rest wherever we want. Thus there are $|\beta I|^{|I|}$ different maps $I\to\beta I$ with dense image. Since $|\beta I|=2^{2^{|I|}}$ (by a well-known theorem of Hausdorff; see this answer, for instance), this means there are $2^{2^{|I|}}$ such maps.
We have thus shown that there are $2^{2^{|I|}}$ different injective homomorphisms $P(I)\to P(I)$. However, we aren't done, because different homomorphisms might correspond to the same subalgebra. If two injective homomorphisms $f,g:P(I)\to P(I)$ have the same image, then $f^{-1}\circ g$ defines an automorphism $h:P(I)\to P(I)$ such that $g=f\circ h$. There are only $2^{|I|}$ such automorphisms (since each one comes from a bijection $I\to I$), and so each subalgebra can only come from $2^{|I|}$ different injective homomorphisms $P(I)\to P(I)$. Thus there must actually be $2^{2^{|I|}}$ different subalgebras of $P(I)$ that are isomorphic to $P(I)$ (and hence complete and atomic).
(If you want to express this all directly in terms of $P(I)$ without using topological properties of $\beta I$, you can do so as follows. Let $S$ be any set of ultrafilters on $P(I)$ containing all the principal ultrafilters. Define a homomorphism $f:P(I)\to P(S)$ by $f(A)=\{U\in S: A\in U\}$. Since $S$ contains all the principal ultrafilters, it is easy to see this $f$ is injective. If $|S|=|I|$, we can can then compose $f$ with an isomorphism $P(S)\to P(I)$ to get an injective homomorphism $f':P(I)\to P(I)$. Moreover, we can recover the set $S$ from $f'$ as the set of inverse images of the principal ultrafilters under $f'$. Since there are $2^{2^{|I|}}$ different such sets $S$ with $|S|=|I|$, this gives $2^{2^{|I|}}$ different injective homomorphisms $P(I)\to P(I)$.)
In conclusion, I expect that you were actually intended to use the other definition of "complete subalgebra"; i.e. a complete subalgebra is a subalgebra which is complete and such that the inclusion map preserves infinite joins and meets. With that definition, your argument works fine to give a canonical bijection between $E(I)$ and $A(I)$.
