In a general topological space are these properties equivalent ? If not, is there a property (e.g. first countability) that metric spaces possess which makes them equivalent there ? Here are the definitions as I understand them.
Bolzano-Weierstrass Property: every infinite sequence $(x_n)$ in X has an accumulation point in X, i.e. a point x such that every open set that contains x contains an infinite number of the points in $(x_n)$
Sequentially compactness: every infinite sequence in X has a convergent subsequence, i.e. converges to a limit, i.e. for every open set O in the topology there is N such that for all n > N then $x_n$ ∊ O (where $(x_n)$ are the points in the subsequence).
Tom Collinge
  • 7,981
  • 25
  • 59
    not equivalent in general, but equivalent for first countable spaces http://math.stackexchange.com/questions/72332/compact-but-not-sequentially-compact-question – Mirko Dec 12 '15 at 16:17
    Also, http://planetmath.org/sequentiallycompact and https://proofwiki.org/wiki/First-Countable_Space_is_Sequentially_Compact_iff_Countably_Compact and https://en.wikipedia.org/wiki/Countably_compact_space and https://en.wikipedia.org/wiki/Sequentially_compact_space and https://dantopology.wordpress.com/2010/07/18/sequentially-compact-spaces-i/ and http://people.math.sc.edu/nyikos/B4.pdf – Mirko Dec 12 '15 at 16:27
The two properties are equivalent if and only if the topological space admits local bases countable, i.e. $(X, \mathcal{T})$ is $N_1$.
In fact, if X is a space sequentially compact, then for all $\lbrace x_n \rbrace \subset X$ exists $x_{n_k} \rightarrow x$, and it is easy to conclude that $x$ is a point of accumulation for $\lbrace x_n \rbrace \subset X$. Conversely, if $x$ is a point of accumulation for $\lbrace x_n \rbrace \subset X$, considers a countable local base $\mathcal{U}(x)=\lbrace U_m : m \in \mathbb{N} \rbrace$. We can assume that $U_{m+1} \subset U_m$ $\forall m \in \mathbb{N}$ (why?). Since $x$ is an accumulation point, we can define a sequence of integers $m_k$ such that $m_{k} < m_{k+1}$ with $x_{m_k} \in U_{m}$, consequently $x_{m_k} \rightarrow x$.
user288972
  • 2,360
