It is quite easy to prove that if $[X_t \}_{t \in [0,T]}$ is a martingale, then for any number $a \in \mathbb{R}$ $ \{\max (X_t,a)\} _t$ is a submartingale and $ \{\min (X_t, a)\} _t$ but I cannot come up with a counterexample which proves that those need not be martingales.
That is, I want to find a martingale $\{X_t\}_{t \in [0,T]}$ and a constant $a \in \mathbb{R}$ such that $$\mathbb{E}\left(\max (X_t,a) | F_s \right) < \max(X_s, a)$$ for all $s \le t$ and adequately for minimum: $$\mathbb{E}\left(\min (X_t,a) | F_s \right) > \min(X_s, a)$$ for all $s \le t$
Could you tell me how/where to look for such examples?
BCLC
  • 13,459
Sasha
  • 363
    "I cannot come up with a counterexample which proves that those need not be martingales." This is rather surprising since every martingale works (except when $X_t\geqslant a$ almost surely or $X_t\leqslant a$ almost surely, naturally). – Did Jan 04 '16 at 16:10
Hint: An easier way to show that $(Z_t)$ is not a martingale is to find some $t$ with $\mathbb{E}(Z_0)\neq \mathbb{E}(Z_t)$.
  • Thank you. Could you tell me how I can modify a martingale, that is what constant $a$ to choose so that the expectations may differ for a certain $t$? – Sasha Dec 03 '15 at 18:58
  • Can we for example take the absolute value of a random variable? For $X_1, X_2, ...$ iid with $P(X_i = 1) = P(X_i = -1) = 1/2$ ${ S_n }$ is a martingale. And here we have $\mathbb{E}(S_n) = 0$ and also $\mathbb{E}(|S_n|) = 0$ but I think it's not a martingale... – Sasha Dec 03 '15 at 19:11
  • No, that was very stupid. We have $\mathbb{E}(S_1) =\mathbb{E}(X_1) = 0$ but $\mathbb{E}(|S_1|) =\mathbb{E}(|X_1|) = 1$ and $\mathbb{E}(|S_2|) =\mathbb{E}(|X_1 + X_2|) =2$ because $|X_1 + X_2| \in {0,2}$ with probabilities $1/2, 1/2$ – Sasha Dec 03 '15 at 19:42
  • And when it comes to minimum we could take the negative part $\min(S_n, 0)$ and get similar results to those above. Is that right? – Sasha Dec 03 '15 at 19:45
-2
Let $(\Omega, \mathscr F, \{\mathscr F_t\}_{t \in [0,T]}, \mathbb P)$ be a filtered probability space where $T > 0$.
If we have two $(\{\mathscr F_t\}_{t \in [0,T]}, \mathbb P)-$martingales $X$ and $Y$, it does not follow that $\max(X,Y)$ is a $(\{\mathscr F_t\}_{t \in [0,T]}, \mathbb P)-$martingale. $\tag{*}$
Now, $\forall a \in \mathbb R$ the stochastic process $A = (A_t)_{t \in [0,T]}$ given by $a = A_t \ \forall t \in [0,T]$ is a $(\{\mathscr F_t\}_{t \in [0,T]}, \mathbb P)-$martingale.
Following the proof of $(*)$, we can show that it does not follow that $\max(X,A) = (\max(X_t,a))_{t \in [0,T]}$ is a $(\{\mathscr F_t\}_{t \in [0,T]}, \mathbb P)-$martingale.
Pf based on answers here:
Let $(\Omega, \mathscr F, \mathbb P)$ be our probability space.
Let $X_0, X_1, X_2, ...$ be iid random variables s.t.
$$P(X_i = 1) = 1/2 = P(X_i = -1)$$
Define $W^X_n := \sum_{i=0}^{n} X_i$.
Consider the filtration $\mathscr F_{n} := \mathscr F_{n}^X$ for $n = 0,1,...$
Note that $W^X_n$ is a martingale w/rt $\mathscr F_{n}$.
Let $a \in \mathbb R$. Consider $M = (M_n)_{n \in \mathbb N}$ where
$$M_n := \max(W_n^X, a) = W_n^X 1_{A_n} + a 1_{A_n^C}$$
where $A_n = \{W_n^X \ge a\}$ and $0 < P(A_n) < 1 (**)$
Let us try to show (and hopefully fail in trying) that $E[M_n|\mathscr F_{n-1}] = M_{n-1}$:
$$E[M_n|\mathscr F_{n-1}] = E[W_n^X 1_{A_n} + a 1_{A_n^C}|\mathscr F_{n-1}] $$
$$= E[W_n^X 1_{A_n}|\mathscr F_{n-1}] + E[a 1_{A_n^C}|\mathscr F_{n-1}] $$
$$= E[W_n^X 1_{A_n}|\mathscr F_{n-1}] + a E[1_{A_n^C}|\mathscr F_{n-1}] $$
Now consider this. If at time 1, we have that $W_1^X = a + 0.5$ it's possible that at time 2, we have $W_2^X = a - 0.5$. Thus, $M_2 = a$ but $M_1 = W_1^X$
Formally:
If at time n, we have $\omega \in A_n$ (ie $W_n^X(\omega) \ge a$), then
$$E[M_n|\mathscr F_{n-1}] = E[W_n^X 1_{A_n}|\mathscr F_{n-1}] + 0$$
$$= E[W_n^X|\mathscr F_{n-1}] = W_{n-1}^X$$
But is it that $W_{n-1}^X = M_{n-1}$?
Not necessarily. It could be that $\omega \in A_{n-1}^C$ (ie $W_{n-1}^X(\omega) \le a$). Hence, $M_{n-1} = a$
$\therefore,$ it is not necessarily true that $E[M_n|\mathscr F_{n-1}] = M_{n-1}$. QED
I hope you don't mind that I used $\mathbb N$ instead of $[0,T]$ :P
Oh also $P(A_n) \notin \{0,1\}$ is important:
If $P(A_j) = 0$ or $1 \ \forall j \in \mathbb N$, then $M_n$ is $W_n^X$ or a a.s. Hence, $M$ is a $(\{\mathscr F_n\}_{(n \in \mathbb N)}, \mathbb P)-$martingale (at least almost surely) because such implies $1_{A_1} = 1_{A_2} = ...$ a.s., in particular, $1_{A_n} = 1_{A_{n-1}}$ a.s..
This might be relevant: Is a probability of 0 or 1 given information up to time t unchanged by information thereafter?
BCLC
  • 13,459
    Where are we supposed to find an example, or a proof, that $(\max(X_t,a))_t$ is not a martingale in all this? – Did Jan 04 '16 at 16:11
  • @Did The first part? It follows from $()$. Did you downvote? Is $()$ false? Is my proof wrong? – BCLC Jan 04 '16 at 18:03
    The first part does not provide any example of a martingale $(X_t)$ and a real number $a$ such that $(Y^a_t)$ is not a martingale, with $Y^a_t=\max(X_t,a)$, nor any way to show that such would exist. You know, what the OP is asking about... – Did Jan 04 '16 at 18:08
  • @Did I edited. Sorry for any confusion – BCLC Jan 04 '16 at 18:09
    Still not answering the question in the least. – Did Jan 04 '16 at 18:12
  • @Did Ah wait. Now I think I understand you. A maximum of two martingales is not necessarily a martingale but it could be. I merely provided a counterexample proving $(*)$ but not really answering OP. Okay going to edit. thanks ^-^ – BCLC Jan 04 '16 at 18:44
  • @Did Done. Thanks again. – BCLC Jan 04 '16 at 18:52
  • Still no proof. (I am tired of mentioning the fact so, if no further comment is added, please consider the present one still holds.) – Did Jan 04 '16 at 19:40
