Yesterday, I sat for my Real Analysis II paper. There I found a question asking to integrate $\displaystyle\int_0^1 xe^x \, dx$ without using antiderivatives and integrating by parts.
I tried it by choosing a partition
$$P_n=(0,\frac{1}{n},\frac{2}{n},\ldots,\frac{n-1}{n},1),$$
but I was not able to show that $\displaystyle \lim_{n \to \infty} U(f,P_n)=\lim_{n \to \infty} L(f,P_n)=1$
RRL
  • 90,707
Angelo Mark
  • 5,954
We have
$$U(f,P_n) = \frac1{n^2} \sum_{k=1}^n k e^{k/n}= L(f,P_n) + \frac{e}{n}.$$
If the limit of the upper sum exists, then it is identical to the limit of the lower sum.
Note that
$$\sum_{k=1}^nk r^k = \frac{r-r^{n+1}}{(1-r)^2}- \frac{nr^{n+1}}{1-r}.$$
Using $r = e^{1/n}$ we have as $n \to \infty$
$$U(f,P_n)= \frac{1/n}{1-e^{1/n}}\frac{1/n}{1-e^{1/n}}e^{1/n}(1-e)- \frac{1/n}{1-e^{1/n}}e^{1/n}e \to 1,$$
since
$$\lim_{n \to \infty} \frac{1/n}{1-e^{1/n}}= -1$$
RRL
  • 90,707
My answer:
$U(f,P_n)=\frac{1}{n^2}\left(e^{\frac{1}{n}}+2e^{\frac{2}{n}}+3e^{\frac{3}{n}}+...+ne^1\right)=\frac{1}{n^2}\displaystyle\sum_{k=1}^{n}ke^{\frac{k}{n}}=\frac{1}{n^2}\displaystyle\sum_{k=1}^{n}k\left(1+\frac{k}{n}+\frac{k^2}{2!n^2}+\frac{k^3}{3!n^3}+..\right)=\frac{1}{n^2} \displaystyle\sum_{k=1}^{n}k+\frac{1}{n^2}\displaystyle\sum_{k=1}^{n}k\left(\frac{k}{n}+\frac{k^2}{2!n^2}+\frac{k^3}{3!n^3}+..\right)=\frac{n(n+1)}{2n^2}+\frac{n(2n+1)(n+1)}{2!6n^3}+\frac{n^2(n+1)^2}{3!4n^4}+....$
Thus when $n\to \infty $ , $U(f,P_n)=\frac{1}{2}+\frac{1}{2!6}+\frac{1}{3!4}+\frac{1}{4!30}+..$ should be 1
Angelo Mark
  • 5,954
My attempt was wrong. Fixing it with my choice of partition unnecessarily complicates the calculation, especially when a solution exists with the partition the OP selected.
SUGGESTION: What would happen if you change the partition to $P_n=[0,\frac{1}{n},\frac{1}{n-1},\ldots,\frac{1}{3},\frac{1}{2},1]$?
Laars Helenius
  • 7,965
  • 23
  • 35
  • Right. I was simply summing $f(x)$ at the partition points. I overlooked the addition of $\Delta,x$ for the integral. This unnecessarily complicates my solution especially when you found the way out with the OP's partition. – Laars Helenius Dec 01 '15 at 08:25
  • Each of the intervals in the partition needs to be able to reach arbitrary small sizes. You cannot do it with $[0, \frac{1}{n}\dots\frac{1}{2},1]$. – Element118 Dec 01 '15 at 10:08
  • Right. I had been studying absolute continuity recently and used partition tricks like my suggestion a lot. I has been a while since I have calculated a Riemann sum. My rust was showing big time! – Laars Helenius Dec 01 '15 at 10:46
Here is a rather different way of doing it. Let's assume we know the following:
$$\frac{e^t-1}t=\int_0^1e^{xt}\ dx$$
Differentiate both sides (under the integral on the right, which may be proven easily)
$$\frac{(t-1)e^t+1}t=\int_0^1xe^{xt}\ dx$$
And with $t=1$,
$$1=\int_0^1xe^x\ dx$$
