As a brief overview of the below, I am asking for:
- An example of a ring with no maximal ideals that is not a zero ring.
- A proof (or counterexample) that $R:=C_0(\mathbb{R})/C_c(\mathbb{R})$ is a ring with no maximal ideals.
A homework question in my algebra class earlier this year asked to exhibit a ring (necessarily without identity) without any maximal (proper) ideals. For solutions to this, it suffices to exhibit an abelian group $(G,+)$ without maximal (proper) subgroups. For, given such a group, define multiplication to be constantly zero. In this case, $G$ becomes a zero ring without maximal ideals (because ideals correspond to subgroups).
It is not particularly difficult to construct examples of the above. For example, consider $(\mathbb{Q},+)$. Another interesting example is $P=\{z\in\mathbb{C}\mid \exists n\in\mathbb{N}, z^{p^n}=1\}$ with standard complex number multiplication as "addition" (that is, as the abelian group operation).
However, any example constructed in this manner is a zero ring, and as such seems "artificial," which I admit, is not a rigorous term. I would like to find a somewhat less artificial example of a ring without maximal ideals. For a definition of "less artificial," let us start with "not a zero ring."
I have a candidate in mind, but I am having trouble explicitly proving that it has no maximal ideals. Let $C_0(\mathbb{R})$ denote the ring of continuous real-valued function on $\mathbb{R}$ vanishing at infinity. Let $C_c(\mathbb{R})$ denote the (two-sided) ideal of compactly supported functions. I believe that the ring $R:=C_0(\mathbb{R})/C_c(\mathbb{R})$ contains no maximal ideals, but I am having trouble showing it.
My intuition for this problem is as follows. Given a function $f\in C_0(\mathbb{R})$, $f(x)$ approaches zero at some "rate" as $x\to\pm\infty$ (possibly different based on $\pm$). Furthermore, for any given rate, we can find a function with a larger rate, in the sense that we can find a $g\in C_0(\mathbb{R})$ such that $f(x)=o(g(x))$ ($f$ is little-$o$ of $g$). Now, even if $f$ is non-vanishing, there is no $h\in C_0(\mathbb{R})$ such that $fh=g$, for any $h$ could not vanish at infinity. Thus the principal ideal generated by $f$ does not contain $g$. By iterating this process we could construct a strictly ascending chain of principal ideals.
Now, the idea is that the ring $R$ consists of these "rates" as described above. I know that this is not precise, or necessarily even correct. But it's my intuition. The previous paragraph shows that we can find an ascending chain of "rates," but a lot of work still needs to be done. If anyone can clean this up, it would be much appreciated.
