I want to prove that every power series is continuous but I am stuck at one point.
Let $\sum\limits_{n=0}^\infty a_n(x-x_0)^n$ a power series with a radius of convergence $r>0$ and let $D:=\{x\in\mathbb R:|x-x_0|<r\}$. Then $S(x)=\sum\limits_{n=0}^\infty a_n(x-x_0)^n$ is continuous on $D$.
Proof: Let $x\in D$ and $r_0\in\mathbb R^+$ such that $|x-y_0|<r_0<r$ and for any positive integer $N$ let $S_N(y)=\sum\limits_{n=0}^{N-1} a_n(y-x_0)^n$ and $\phi_N(y)=\sum\limits_{n=N}^\infty a_n(y-x_0)^n$.
Since the power series converges uniformly on the closed disk $|y-x_0|\leq r_0$, we may choose a positive integer $N_\varepsilon$ such that $|\phi_{N_\varepsilon}|<\frac\varepsilon3$ for all $|y-x_0|\leq r_0$.
Since $S_{N_\varepsilon}$ is polynomial we can choose a $\bar\delta>0$ such that $|S_{N_\varepsilon}(y)-S_{N_\varepsilon}(x)|<\frac\varepsilon3$. So we get $|S(y)-S(x)|<\frac\varepsilon3+\frac\varepsilon3+\frac\varepsilon3=\varepsilon$ for $|y-x|<\delta$
Why is in the violet term $|\phi_{N_\varepsilon}|<\frac\varepsilon3$ correct? Don't I have two terms in the absolute value? Thanks for helping!
  • What is the difference between $S_N$ and $\phi_N$ above, their definitions are the same... – copper.hat Jun 04 '12 at 17:31
  • the uniform limit of continuous functions is continuous. If you already do know that power series converge uniformly there does not remain anything to prove. –  Jun 04 '12 at 17:33
  • @copper.hat $S_N$ is from 0 to $N-1$ –  Jun 04 '12 at 17:44
  • @Thomas right, but we're interested in a more specific proof as stated above. –  Jun 04 '12 at 17:46
    If you want to prove that $S(x)$ is continuous in $D$, given $c\in D$, and given $\epsilon\gt 0$ you need to find a $\delta\gt 0$ such that $$|x-c|\lt\delta\implies |S(x)-S(y)|\lt\epsilon.$$ Is that what you are trying to say? Once you understand that, the proof is as you wrote, by dividing the series $S(x)-S(c)$ in two parts. – leo Jun 04 '12 at 17:53
  • I think you want $$\phi_N(y)=\sum_{n=N}^\infty a_n(y-x_0)$$ – leo Jun 04 '12 at 17:56
  • @niro Did you notice all the powers are missing from $,(x-x_0),$? These are not power series but only series. – DonAntonio Jun 04 '12 at 18:10
  • I guess it would be $(x-x_0)^n$. Please consider review your post. If you put effort on your question it is easier to help you :-) – leo Jun 04 '12 at 18:26
  • @leo EXACTLY, this is what I want to do! At the end I have $|S(y)-S(x)|=|S_{N_\varepsilon}(y)+\phi_{N_\varepsilon}(y)-S_{N_\varepsilon}(x)-\phi_{N_\varepsilon}(x)|$ and then it's via triangle inequality as stated above. So why is $|\phi_{N_\varepsilon}(y)|<\frac\varepsilon3$ as above correct this way? –  Jun 04 '12 at 18:36
  • I prefer to use the Weierstrass M-test and completeness of continuous functions under the $\sup$ norm. – copper.hat Jun 04 '12 at 19:39
  • @copper.hat post an answer, it would be useful! – leo Jun 04 '12 at 19:41
Choose $z \in D$ and select $\delta >0$ so that $C = \overline{B}(z,\delta) \subset D$. Let $\rho = |z-x_0|+\delta$, note that $\rho < r_0$ and that $C \subset \overline{B}(x_0,\rho) \subset D$.
Then let $M_n = |a_n|\rho^n$, and note that $|a_n(x-x_0)^n | \leq M_n$, $\forall x \in C$, and $\sum M_n < \infty$.
Hence we can use the Weierstrass M-test to conclude that the series $\sum a_n (x-x_0)^n$ converges uniformly on $C$. Since each of the functions $\sum_{n<N} a_n (x-x_0)^n$ is trivially continuous, it follows from the uniform limit theorem that the limit function $x \mapsto \sum a_n (x-x_0)^n$ is continuous on $C$. Since $z\in D$ was arbitrary, the desired result follows.
copper.hat
  • 172,524
