a. Prove that the interval $A = [1,3]$ has the same cardinality as $B = [1,5]$ by writing down a bijection from $A \to B$. Don't prove it is a bijection.
b. Consider the following infinite set: $A = {1, \frac{1}{2}, \frac{1}{3}, \frac{1}{4},..., \frac{1}{n}}$, Prove the set $A$ has the same cardinality as the integers by writing down a . bijection from $A$ onto $Z$.
I don't know how to find a function that is a bijection from one set to another. Can anyone help by explaining the thought process behind it, I've been having trouble with these types of problems? Thanks.
Don
  • 636
Hint for a. We want to use simple functions. Let's use a linear function $f: A \to B$. Find a linear function
$$ f(x) = ax + b$$
such that $f(1) = 1$ and $f(3) = 5$.
Hint for b. Can you find a bijection $g: A \to \mathbb{N}$? And do you remember a bijection $h: \mathbb{N} \to \mathbb{Z}$? Then you can simply combine those and obtain a bijection $h \circ g: A \to \mathbb{Z}$.
Niklas
  • 488
