Let $(M, g)$ be a Riemannian Manifold of dimension $d$, $g$ naturally gives rise to an invariant volume form $V_M \in \Omega^d(M)$.
Let $\Sigma$ be a smooth embedded submanifold of dimension $d-1$ in $M$. One can pull back the metric $g$ by the embedding map and construct am invariant volume form $V_\Sigma \in \Omega^{d-1}(\Sigma)$.
Question: Is it true that
\begin{equation} V_\Sigma = i_nV_M \end{equation}
where $n|_p$ is the unit normal with respect to $g$ at $p \in \Sigma$.
Comments:
I think it is well known (and easy to check) that the above equation is true for surfaces in $\mathbb R^3$, but I am not sure if it holds in general.
If not true, is there a general equation of this type where one can express the "induced volume element" in terms of the global volume element, without explicit reference to the metric?
