When fleshing out proofs in topology, or any area of mathematics for that matter, I suggest that you simply start writing out what you have in front of you in as concrete form as possible.
Let $f,g \in C[a,b]$ the "distance" between these two in the sup metric is
$$ d'(f,g) = \sup_{x \in [a,b]} |f(x) - g(x)|$$
furthermore the distance between their mapping in the respective euclidean metric is
$$ d(\Phi(f),\Phi(g)) = \left| \int_a^b f(x) \ dx - \int_a^b g(x) \ dx \right| = \left| \int_a^b (f(x) - g(x)) \ dx\right|$$
Now as you stated if we fix $f \in C[a,b]$ if we can show that
$$ \forall \varepsilon > 0 : \exists \delta > 0 : \forall g \in C[a,b] : d'(f,g) < \delta : d(\Phi(f), \Phi(g)) < \varepsilon$$
then this proves that $\Phi$ is continuous at $f$.
The definition of continuity hints at the fact that if we are able to find a suitable relationship between $\varepsilon$ and $\delta$ such that there always exists a suitable distance $\delta$ between the functions $f$ and $g$ then their respective mappings are also close together. So let's get to work!
Fix $f \in C[a,b]$ and lets do some scratch work. The distance between some other function $g \in C[a,b]$ is given above by
$$d(\Phi(f), \Phi(g)) = \left| \int_a^b (f(x) - g(x)) \ dx\right|$$
since you are taking topology I assume you are also at least a bit familiar with analysis, in analysis proofs you probably started by trying to find a suitable evaluation in the form of an inequality, we are going to do the same thing here, but we have to keep in mind that the initial space is not the standard euclidean metric, but instead it is the sup metric. We don't have much choice so first we evaluate this integral to a larger one
$$ \left| \int_a^b (f(x) - g(x)) \ dx\right| \leq \int_a^b |f(x) - g(x)| \ dx$$
I am going to leave the next step to you, but think closely about what we wish to achieve. We have to somehow get the sup metric in here, and we are extremely close. As a hint consider one more inequality upwards, how could we evaluate this integral in order to get the distance between $f$ and $g$ into the mess? Once you have achieved this, then think about what sort of relationship between $\varepsilon$ and $\delta$ we need. For instance if
$$ M \in \mathbb{R} : d'(\Phi(f), \Phi(g)) < M d(f,g) $$
Then if we choose $\delta > 0 : \delta = \frac{\varepsilon}{M}$ then clearly
$$d(f,g) < \delta \iff d(f,g) < \frac{\varepsilon}{M}$$
and combining the above inequalities would give us what we want!
