13
Dumb/Challenging conventional wisdom question possibly related to my previous question.
Why do we sometimes consider a measure space $(S, \Sigma, \mu) = (\mathbb{R}, \mathscr{B}(\mathbb{R}), \lambda)$ where $\lambda$ is Lebesgue measure rather than $(S, \Sigma, \mu) = (\mathbb{R}, \mathscr{M}(\mathbb{R}), \lambda)$ where $\mathscr{M}(\mathbb{R})$ is the set of $\lambda$-measurable subsets of $\mathbb{R}$? I mean, there are subsets of $\mathbb{R}$ that are not Borel sets but $\lambda$-measurable right? If there are none, I guess that answers the first question.
Possibly answered by above but why, in my previous question, is it 'natural' to consider $\mathscr{F}$? I'm guessing it's like why it's 'natural' to consider $\mathscr{B}(\mathbb{R})$.
Possibly related:
Why do probabilists take random variables to be Borel (and not Lebesgue) measurable?
BCLC
  • 13,459
    Considering the relation between Legesgue integration and Riemann integration over $\Bbb{R}$ may be helpful. – Yes Nov 03 '15 at 12:10
  • @GudsonChou Thanks for the hint. I guess it's related to that. That would explain 'Borel' here. Elaborate further though pls? Why Borel function? Also, is such integration THE reason or A reason? – BCLC Nov 03 '15 at 13:13
    Borel sets are all you need for many things (e.g. classical probability) and the theory getting you to Borel sets is much simpler than that getting you to the class of measurable sets. – Gregory Grant Nov 03 '15 at 13:27
  • @GregoryGrant Thanks! Got any examples? If so, you could post as answer already I guess – BCLC Nov 03 '15 at 13:38
Well i'd say it depends of the context but one reason that come to my mind is that the borel $\sigma$-algebra is simpler (and smaller) than the Lebesgue $\sigma$-algebra $\mathscr{M}(\mathbf{R})$. For a lot of things the seting of borel functions or borel sigma alegbra is enough for what you want to do, using the Lebesgue sigma algebra would only make the proofs harder or even invalidate the results you want to prove.
An example about the "harder proofs" parts : the $\sigma$-algebra $\mathscr{B}(\mathbf{R})$ is generated by the open sets of $\mathbf R$, and a lot of proofs use this fact. Unfortunatly the situation is more complex with $\mathscr{M}(\mathbf R)$.
An example about the "invalidating results" part : It's easy to show that if $f$ and $g$ are Borel then $f\circ g $ is also Borel. However, if you define a measurable function to be a function $f$ such that for every open set $U\subset \mathbf R$ you have $f^{-1}(U)\in \mathscr M (\mathbf R)$ then the composition of two measurable functions is not measurable in general.
Side note : the fact that the composition of a two measurable functions is not measurable is closely related to the fact that some functions are Borel but not Lebesgue (where $f$ is Lebesgue mean $f^{-1}(U)\in \mathscr M (\mathbf R)$ for every $U\in \mathscr M (\mathbf R))$. There is a exercice in Folland's Real analysis about that if i remember it right. But $\mathscr M (\mathbf R)$ is absolutely crucial in integration theory, indeed there are functions that are Riemann integrable but not Borel (think of the characteristic functions of some subset of the triadic cantor set).
To finish, yes $\mathscr M (\mathbf R)\backslash\mathscr B (\mathbf R)$ is nonempty. But you have the following result :
if $A\in \mathscr M (\mathbf R)\backslash\mathscr B (\mathbf R)$ then there exists two borel sets $M$ and $N$ such that $M\subset A$, $A\subset M \cup N$ and $\lambda(N)=0$ (so $A$ is a borel set up to some non Borel negligible set). Moreover one have $\lambda(A)=\lambda(M)$.
Renart
  • 2,948
  • Thanks Renart! So A is kind of approximated by M or something? Any thoughts on Q3? – BCLC Nov 06 '15 at 11:31
  • Wait is 'natural' kind of like 'enough for what you want to do, using the Lebesgue sigma algebra would only make the proofs harder or even invalidate the results you want to prove' ? – BCLC Apr 16 '18 at 16:04
  • do you disagree with the answer i posted? – BCLC Apr 16 '21 at 15:55
    But a measurable function is one for which the preimages of measurable sets are measurable, not the preimages of open sets (open sets aren't even a well defined notion in general measurable spaces). The composition of measurable functions is always measurable, even if they map between completely unrelated measurable spaces. If $f:X\to Y$ and $g:Y\to Z$ are measurable, where $X,Y,Z$ are arbitrary measurable spaces, then $g\circ f:X\to Z$ is also measurable. – Vercassivelaunos Aug 21 '21 at 10:39
  • Who defines measurable functions such that the preimage of open sets must be measurable? I have never heard that (except for this answer)? – Lukas Betz Aug 21 '21 at 10:49
  • @Vercassivelaunos : Note that the question is not about an arbitrary measurable space but about $\mathbb R$. Also since we're talking about Borel sets open sets are obviously well defined. The usual definition on $\mathbb R$ is "the preimage of any borel set is measurable", which is equivalent to "the preimage of any open set is measurable". Check for example wikipedia : https://en.wikipedia.org/wiki/Measurable_function#Notable_classes_of_measurable_functions the $\sigma$-algebra is $\mathcal M(\mathbb R)$ on one side and $\mathcal B(\mathbb R)$ on the other. – Renart Aug 28 '21 at 14:13
  • But you said that if you define a measurable function such that the preimage of open sets is measurable, then basic results wouldn't hold. However, no-one would do such a thing. Just because in the Borel case it so happens that you can replace one instance of "measurable" by "open", doesn't mean that you can do so in general (or more specifically, in the Lebesgue case). If we're talking about the Lebesgue $\sigma$-algebra, we have to extend the concept of measurable functions in a sensible way. Preimages of open sets being measurable is not sensible (without additional conditions). – Vercassivelaunos Aug 28 '21 at 14:46
    Have you looked at the wikipedia page I linked ? For real functions a measurable function usually means that the preimage of any borel set is a measurable set (ie in the Lebesgue $\sigma$-algebra), which is equivalent to "the preimage of any open set is measurable" since the Borel $\sigma$-algebra is generated by open sets. It IS the usual definition on the real line and the question IS about the real line. – Renart Aug 30 '21 at 16:27
The first observation to make here is there's a difference between a measurable space (that is, a set paired with a $\sigma$-algebra) and a measure space (that is, a measurable space equipped with a measure). I challenge you to find examples where the measure space $(\mathbb{R},\mathscr{B}(\mathbb{R}),\lambda)$ is being studied in a non-trivial manner without implicit reference to $\mathscr{M}(\mathbb{R})$. On the other hand, the measurable space $(\mathbb{R},\mathscr{B}(\mathbb{R}))$ is a natural place to do measure theory.
The issue with $(\mathbb{R},\mathscr{B}(\mathbb{R}),\lambda)$ is it is not a complete measure space. That is, null sets of $\lambda$ need not be measurable. In a sense, once you know what measure you want to put on your measurable space, you should complete it immediately (which you're free to do). Why? Many of the theorems of integration are more naturally stated if you assume completeness, and you're less likely to run into annoying paradoxes. For example, if you give me a set $B \in \mathscr{M}(\mathbb{R}) \setminus \mathscr{B}(\mathbb{R})$, then $\chi_{B}$ is Lebesgue but not Borel measurable. Nonetheless, I can find a sequence $(\varphi_{n})_{n \in \mathbb{N}}$ of smooth functions such that $\varphi_{n}(x) \to \chi_{B}(x)$ for almost every $x \in \mathbb{R}$.
The way I think of this is, once you have a measure in mind, you should complete the space. I haven't come across a counter-example to this rule of thumb yet.
While I don't think $(\mathbb{R},\mathscr{B}(\mathbb{R}),\lambda)$ is a very interesting measure space, $(\mathbb{R},\mathscr{B}(\mathbb{R}))$ is an important measurable space. This is easiest to see in the context of probability.
Suppose we have a probability space $(\Omega,\mathcal{F},\mathbb{P})$ and we're interested in a function $X : \Omega \to \mathbb{R}$, as one often is. Probably we're not interested in knowing $X$ pointwise, that is, in understanding the function $\omega \mapsto X(\omega)$, since somewhat implicit in the set-up of a probability space is we don't know which outcomes $\omega$ in $\Omega$ we're dealing with. The set-up of measure-theoretic probability is instead that we would like to know $\mathbb{P}\{X \in A\}$ for a rich enough collection of subsets $A$ of $\mathbb{R}$. This is only well-defined if the events $\{X \in A\}$ are in $\mathcal{F}$ to begin with. In other words, we need to understand a little bit about the push forward $\sigma$-algebra $\mathcal{F}_{X} = \{A \subseteq \mathbb{R} \, \mid \, X^{-1}(A) \in \mathcal{F}\}$.
What sets should $\mathcal{F}_{X}$ contain in general? This is up to how you want to define probability theory. The standard set-up is $X$ is a random variable if the push forward $\sigma$-algebra contains $\mathscr{B}(\mathbb{R})$. Why? Well, one way to think about random variables it to ask that, at the very least, we should be able to compute $\mathbb{P}\{X \leq c\}$ for arbitrary real numbers $c$. More rigorously, we should demand that $\{X \leq c\} \in \mathcal{F}$ (or $(-\infty,c] \in \mathcal{F}_{X}$) independently of the choice of $c$.
However, the collection $\{(\infty,c] \, \mid \, c \in \mathbb{R}\}$ generates $\mathscr{B}(\mathbb{R})$ so if the $\mathcal{F}_{X} \supseteq \{(-\infty,c] \, \mid \, c \in \mathbb{R}\}$, then it contains $\mathscr{B}(\mathbb{R})$. In fact, the following result holds:
The following are equivalent:
1) $\mathscr{B}(\mathbb{R})\subseteq \mathcal{F}_{X}$
2) $\forall c \in \mathbb{R} \quad \{X \leq c\} \in \mathcal{F}$
3) $\forall c \in \mathbb{R} \quad \{X < c\} \in \mathcal{F}$
4) $\forall c \in \mathbb{R} \quad \{X \geq c\} \in \mathcal{F}$
5) $\forall c \in \mathbb{R} \quad \{X > c\} \in \mathcal{F}$
6) If $U \subseteq \mathbb{R}$ is open, then $\{X \in U\} \in \mathcal{F}$
7) If $C \subseteq \mathbb{R}$ is closed, then $\{X \in C\} \in \mathcal{F}$
The point is if you want to be able to ask questions about random variables involving the topology (or ordering) of $\mathbb{R}$, then you need the random variable to be measurable from $(\Omega,\mathcal{F},\mathbb{P})$ into $(\mathbb{R},\mathscr{B}(\mathbb{R}))$ at a minimum. This is why the modern theory of probability defines (real-valued) random variables in terms of $(\mathbb{R},\mathscr{B}(\mathbb{R}))$.
I'm not sure what you have in mind when you say example, but if you look in a basic (undergraduate level) probability book you'll see they really struggle with the fact that you can't give a probability to any arbitrary event. The question then becomes what subset of $2^{\mathbb R}$ you want to consider. There's some desire to be as broad as possible, but the basic machinery that you need to develop is quite difficult and perhaps too difficult for the typical student of classical probability who will probably never encounter in the real world an event that is not a Borel set. In find in teaching probability that even Borel sets are too complicated for the typical student who is a scientist who just wants to test the significance of their data. For such people they will probably never encounter an event that's not an interval, or at most a union of two or three intervals. But such students would be lost in the difficult details of analysis necessary to include more sets than they would actually ever need. That's why some authors, e.g. Larson, side step the entire issue of non-integrable sets completely, and just warn the student that not all subsets of $\mathbb R$ can be events and then just move on.
Gregory Grant
  • 14,874
Probability perspective:
PART I
It is more natural to use Borel sets than Lebesgue measurable sets because
  1. From elementary probability, the cumulative distribution function is $$F_X(x) = P(X \le x) = P(\{X \le x\}) = P(X \in (-\infty, x]).$$ That is, we often investigate probabilities (measures) of random variables (measurable functions) in sets of the form $(-\infty, x]$
  2. Now if you collect those sets, we have a $\pi$-system:
$$\pi(\mathbb R) := \{(-\infty, x] \ | \ x \in \mathbb R \}$$
Then finally
$$\sigma(\pi(\mathbb R)) = \mathscr B (\mathbb R)$$
Thus, the sets in $\mathscr M (\mathbb R) \setminus \mathscr B (\mathbb R)$ don't really need to be considered.
PART II
Also in line with this, thus probably explaining why this is a dumb question, Borel sets are more on the output than input of random variables. Measurable sets are the input. Thus, Lebesgue measure or whatever measure ($\mathbb P$) would be used, would be more for computing probabilities that certain random variables are in Borel sets rather than the computing length of the Borel sets or anything.
BCLC
  • 13,459
