This is related to a question I just asked, that I now think was based on wrong assumptions.
It is true that if $f=a$ a.e. on the interval $[a,b]$, then $f = a$ on $[a,b]$. However, apparently it is not true for a general measurable set $E$ with $m(E) \neq 0$, which confuses me greatly.
I just finished the following proof which I thought showed that the statement was true for a general measurable set $E$. Apparently, it's not. Could somebody please tell me 1) what's wrong with it, 2) how to fix it, 3) how to use it to show that the statement is not true for $E$ with $m(E) \neq 0$ (or whichever kind of set it doesn't work for):
Suppose $f$ and $g$ are continuous on the general measurable set $E$. Suppose also that $E_{0}\subseteq E$ is the set of all points where $f \neq g$ are all contained (i.e., $\forall x \in E_{0}$, $f \neq g$), where $m(E_{0})=0$.
Consider $|h|=|f-g|$. $|h|$ is the composition of a continuous function and the linear combination of two continuous functions, so $|h|$ is continuous.
Now, $E_{0} = |h|^{-1}(\mathbb{R}\backslash\{0\})=h^{-1}((-\infty,0)\cup (0,\infty))$. $(-\infty,0)\cup(0,\infty)$ is a union of open sets and therefore open. Since $|h|$ is continuous, $E_{0}$ is also open.
Since $E_{0}$ is open and $m(E_{0})=0$, it must be empty (as otherwise, it must contain a nonempty interval, whose measure would be positive.
Therefore, since the set of points on which $f \neq g$ is empty, $f=g$ everywhere on $E$.
  • I think your statement should be * If $f=a $ a.e. and f is continuouse on $[a,b]$, then $f=a$ on $[a,b]$*. – Nizar Oct 28 '15 at 16:11
  • @Nizar, fixing it. –  Oct 28 '15 at 16:13
  • This statement is not necessarily true if $E$ is a general measurable set: "Since $E_{0}$ is open and $m(E_{0})=0$, it must be empty (as otherwise, it must contain a nonempty interval, whose measure would be positive." This assumes that $E$ itself contains an interval, which need not be the case. –  Oct 28 '15 at 16:24
    The inverse image of the open set is only necessarily relatively open in the domain of $h$, but might not be open in general. – T.J. Gaffney Oct 28 '15 at 16:26
    @Bungo. It is true that all non-empty, open subsets of the reals contain an interval. (In fact they are the union of countably many open intervals.) – T.J. Gaffney Oct 28 '15 at 16:28
  • @Gaffney, we're not talking about topologies, just $\mathbb{R}$ with the Lebesgue measure. –  Oct 28 '15 at 16:30
  • @Bungo, yes, I am talking about general measurable sets in $\mathbb{R}$, not in more abstract spaces. –  Oct 28 '15 at 16:31
    @Gaffney: Sure, but the domain of the functions (or at least the set on which they are continuous, which is the only set on which the argument is valid) is some general measurable set $E \subset \mathbb R$, not necessarily all of $\mathbb R$. –  Oct 28 '15 at 16:32
  • I think that Bungo is true. Take the example given by B.S Thomson, put $f(x)=g(x)=x$ on $[0,1]$, $f(2)=0$, $g(2)=1$. Then $f$ and $g$ are continuous on $E=[0,1]\cup {2}$, and your $E_0$ is equal to ${2}$, which is an not empty open subset of $E$ (it is $E\cap ]1,3[$), but with measure $0$. – Kelenner Oct 28 '15 at 16:42
    The error in the the proof is in the sentence "Since $|h|$ is continuous, $E_{0}$ is also open". The set $E_{0}$ is not open in $\mathbb{R}$. It is simply open in $E$. And since $E$ is a general measurable set, you may have $E_{0}$ open in $E$, $m(E_{0})=0$ and $E_{0} \neq \emptyset$. – Ramiro Oct 28 '15 at 19:12
I am not normally a cat person but this one and I are old friends now.
So I think I should jump into the litter box and complete the task we have been set. What is the definitive answer to this problem that was apparently given to all the kittys in a graduate class somewhere? Here is a way to formulate and answer the problem.
Definition. A set $E$ of real numbers is said to be a purrfect set if whenever $f$, $g:E\to R$ are continuous functions and $N\subset E$ is a set of Lebesgue measure zero for which $f(x)=g(x)$ for all $x\in E\setminus N$ it follows that $f(x)=g(x)$ for all $x\in E$.
Don't confuse purrfect with perfect.
  1. $[0,1]$ is a purrfect set [proved by J. Cat].
  2. $[0,1] \cup \{2\} $ is not a purrfect set [checked by J. Cat].
  3. Every open set is a purrfect set [method of J. Cat works].
  4. Every set open in the density topology is a purrfect set.
Naturally the problem is not complete until we characterize purrfect sets. The following does the job giving a paw-sitive solution to the originally posed problem.
Theorem. A necessary and sufficient condition for a set of real numbers $E$ to be a purrfect set is that for each $x\in E$ and for each $\epsilon>0$ $$m(E\cap(x-\epsilon,x+\epsilon))>0$$ where $m$ is Lebesgue outer measure.
We can leave this as an exercise for all you Cool Cats since the methods should be clear. Note that purrfect sets are kind of thick and furry at each point.
In case you think that purrfect sets might be of little interest and that the instructor who set the problem should be charged with animal cruelty let me leave you with another problem.
Problem. Suppose that $F:R\to R$ is an everywhere differentiable function. Show that the set $$\{x: a<F'(x)<b\}$$ is a purrfect set for any $a$ and $b$.
[My apologies: someone seems to have run my posting through the web site Kittify hence all the cat puns. Too late to edit them out.]
  • Thomson, meow. Is having the set $D$ be a dense subset of $E$ not sufficient? –  Oct 29 '15 at 17:27
  • "Dense" is the key. For your problem what you want is to be sure that $E\setminus N$ is dense in $E$ whenever $N$ is a set of Lebesgue measure zero. The definition here captures this idea. Have you handed in your homework yet? [Sorry I've run out of cat jokes.] – B. S. Thomson Oct 29 '15 at 21:21
Now $E_0 = h^{-1}(\mathbb{R} \backslash \{0\})$ [...] Since $E_0$ is open and $m(E_0)=0$, it must be empty.
No, that's not correct. The continuity of $h$ gives that
$$U := h^{-1}(\mathbb{R} \backslash \{0\}) = \{x \in \mathbb{R}; g(x) \neq f(x)\}$$
is open. This set does not equal
$$E_0 = \{x \in E; g(x) \neq f(x)\} = U \cap E;$$
in particular $E_0$ does not need to be open (at least not in $\mathbb{R}$, it is open in $E$).
Just consider the following example: Set $E := \{0\} \cup [1,2]$ and
$$f(x) := \begin{cases}0, & x \leq 0,\\ x, & x \in [0,1], \\1, & x>1 \end{cases}$$
and $g := 1$. Obviously, $f:\mathbb{R} \to \mathbb{R}$ is continuous and $f=g$ almost everywhere on $E$. However,
$$E_0 = \{0\}$$
is not empty and $f|_E$ does not equal $1$.
saz
  • 120,083
My feline friend is getting confused (and no doubt frustrated) and has now posted a further variant on the problem. Here is the best I can come up with for a short tutorial. I hope it helps.
Do this problem first:
Suppose that $f$, $g:E \to R$ are continuous functions. Let $D$ be a subset of $E$ and suppose that $f(x)=g(x)$ for each $x\in D$. What are the necessary and sufficient conditions on $D$ in order to conclude that $f(x)=g(x)$ for all $x\in E$?
You can do this in a metric space, but it is enough just to assume $E$ is some set of real numbers and that these functions are continuous relative to the set $E$. There is no measure theory here, no measurable sets, no measure zero sets.
If you can't solve this problem, then don't even try the other problem about sets of measure zero since this one is a prerequisite!
In short, forget about measure theory for a while and review what you already have learned about continuous functions, dense sets, etc.
