-4
Let $x_n$ be a sequence such that $|x_n −x_{n+1}|\leq 1/n$. Does this sequence always converge?
Show that $x_n = \sqrt{2 + x_{n−1}}$ is bounded and increasing.
Hint: For the first problem consider the harmonic series.
Before you start the second part check whether you possibly have some extra information about $x_1$. I'm pretty sure you must otherwise you might want to consider say $x_1=100$.
For the second part consider first the increasing part. You should find that quite easy just by writing the appropriate inequality.
To show it's bounded consider at what starting point you stop having the increasing property.
DRF
  • 5,167
