I am using these notes as my reference, but I am running into some questions.
Say I am trying to find, for large $\lambda$ $$I(\lambda)=\int_0^{\pi/2}dxe^{-\lambda\sin^2(x)}$$ This has our maximum at $c=0$, where g(c)=0 and g'(c)$\neq$0. So when I pull out the $e^{\lambda g(c)}$, that is just 1, so I continue to expand g(x) about x = 0, and then change the bounds from -Infinity to Infinity. $$I(\lambda)\approx\int_{-\infty}^\infty dx\exp[-\lambda(x^2-x^4/3+...)]$$ To first order, this is just $\sqrt{(\pi/x)}$, but the second order diverges.
The reason this stumps me is because I can find an exact solution that depends on $e^x$ so I am not sure where i am going wrong in computing the behavior.
$$I = \int_0^1 \frac{dy e^{-\lambda y}}{2\sqrt y\sqrt{1-y}}$$
But can Watsons be used, because the g(y) blows up to infinity as I get to 0?
– yankeefan11 Oct 12 '15 at 18:54
