In addition to answers already given, it might well be that your "analytic expression" will have to be numerically evaluated in applications anyway, and that its evaluation will often be less efficient, more numerically unstable, or even both, than had you just constructed a numerical solution at the outset.
Let me quote the following from Acton, who puts it more eloquently than I ever could:
Formal mathematical training is a frequent if minor villain
in the righteous struggle for efficient computer use. For
example, every college sophomore has seen linear algebraic
equation solving expressed in two lines as $$\begin{align*}&\qquad\mathbf A\mathbf x=\mathbf b\\&\text{so}\\&\qquad\mathbf x=\mathbf A^{-1}\mathbf b\end{align*}$$ It is not surprising that, faced with an equation set, he invokes a computer library program to invert his matrix $\mathbf A$ and then multiply it into $\mathbf b$. The fact that this sequence of operations
takes at least three times as much labor on the part of the computer as a direct solution of the original problem by the elimination of variable technique has never penetrated his consciousness. The glibness of the formal mathematical
notation has obscured the realities of the arithmetic process.
The student that worships at the altars of Classical Mathematics should really be warned that his rites frequently have quite oblique connections with the external world.
and in a later section
$$F(b)=\frac{\pi}{2}\cos b-\left[\cos b\int_0^b\frac{\sin t}{t}\mathrm dt+\sin b\int_b^\infty\frac{\cos t}{t}\mathrm dt\right]\qquad\qquad\text{(10.17)}$$ This formulation of our function is another way to get the series representation. Since the two integrals are functions tabled in several standard references [AMS 55] $\text{(10.17)}$ is also the practical formula for hand evaluation of $F$. When we consider automatic computation, however, this expression for $F(b)$ is virtually useless, since it requires the subcomputation of two nonstandard functions, one of them containing a singularity at the origin. We quote it here merely to stress how different in utility a particular expression may be for hand and automatic computations.
inv(A) * B
can be difficult in casedet(A)
is very small. On the other hand, solvingAx = B
using numerical methods can provide more stable approximations to the true solution. – musically_ut Sep 14 '15 at 20:05
