Help me prove
$$\binom{n}{r} + \binom{n}{r-1} = \binom{n+1}{r}.$$
thanasissdr
  • 6,348
Ishaque
  • 133
Hint: Suppose you have $n+1$ objects and you want to choose $r$ of them, but one of them is $\mathcal{Special}$.
Break it into cases: either you do pick the $\mathcal{Special}$ object or you don't. How many ways are there of doing each?
JMoravitz
  • 79,518
The binomial coefficient ${n}\choose{r}$ is the number of $r$-element subsets of an $n$-element set. So let's consider an $(n+1)$-element set, say the set contains $n$ pennies and one nickel (or $n$ of one kind of thing and one of a different kind of thing). How many $r$ element subsets does this set have? We can choose $r$ pennies, or $r-1$ pennies and one nickel.
$\frac{n!}{r!(n-r)!}+\frac{n!}{(r-1)!(n-(r-1))!}=\frac{(n-(r-1))\times n!}{r!(n-(r-1))!}+\frac{r\times n!}{r!(n-(r-1))!}=\frac{(n+1)\times n!}{r!(n-(r-1))!}=\frac{(n+1)!}{r!((n+1)-r))!}$
Thus they are equivalent
You can start from the definition of the binomial coefficient $\dbinom nr$ as the coefficient of $x^r$ when you develop $(1+x)^n$, and compare the coefficients of $x^r$on both sides of the equation: $$(1+x)^{n+1}=(1+x)(1+x)^n$$ Comparing, you clearly have $\;\dbinom {n+1}r x^r=1\cdot\dbinom nrx^r+x\cdot\dbinom n{r-1}x^{r-1}.$
Bernard
  • 175,478
